Product
Hypertec 4GB PC3-12800 Low Voltage DDR3 SODIMM Memory Module
Quicklinx: 9D7ZWS00 Mfr#: 691740-001-HY
Hypertec - DDR3L - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - 1.35 V - unbuffered - non-ECC - for Compaq 15; HP 255 G3; Pavilion 15, 17; ProBook 450 G0, 455 G1, 470 G0
Hypertec - DDR3L - 4 GB - SO-DIMM 204-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
HP 691740-001
4 GB
Upgrade Type
System specific
HP 691740-001
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
Compaq 15-a001ef, 15-a001sf, 15-a004sg, 15-a004sz, 15-a006sf, 15-a010eb, 15-a013nf, 15-a019sg, 15-a024sg, 15-a026sg, 15-a054so, 15-a055so , HP 255 G3 , HP Pavilion 15-e001so, 15-e003sg, 15-e003so, 15-e004TX, 15-e014nr, 15-e014so, 15-e015nr, 15-e016nr, 15-e042sf, 15-e044sf, 15-e050sf, 15-e051so, 15-e055so, 15-e056so, 15-e057so, 15-e058so, 15-e070so, 15-e071so, 15-e072so, 15-e080so, 17-e001sg, 17-e002sg, 17-e019dx, 17-e021nr, 17-e040sf, 17-e046sf, 17-e050sg, 17-e051sf, 17-e055so, 17-e057so, 17-e058so, 17-e060so, 17-e087eg, 17-e113dx, 17-e117dx, 17-e118dx , HP ProBook 450 G0, 455 G1, 470 G0
