Hypertec - DDR3L - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - 1.35 V - unbuffered - non-ECC - for Lenovo ThinkCentre M600; ThinkPad 11; L460; L560; P40 Yoga; P50; T460; ThinkPad Yoga 11
- Hypertec - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3L SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3L-12800)
- Low Voltage, unbuffered
- Voltage
- 1.35 V
- OEM Manufacturer Equivalent Part Number
- IBM 0B47380
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- System specific
- IBM 0B47380
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Voltage
- 1.35 V
