Your basket is empty
Hypertec 4GB DIMM 240-pin DDR3 Memory Module
Quicklinx: 93KJWS00 Mfr#: B4U36AA-HY
Hypertec - DDR3 - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for HP 280 G1, 63XX, Elite 8300; EliteDesk 70X G1, 800 G1; ProDesk 40X G1, 490 G1, 600 G1
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
HP B4U36AA
HP 280 G1, 6300 Pro, 6305 Pro, Elite 8300; EliteDesk 700 G1, 705 G1, 800 G1; Pro 3500; ProDesk 400 G1, 405 G1, 490 G1, 600 G1
4 GB
Upgrade Type
System specific
HP B4U36AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
HP 280 G1 , HP EliteDesk 700 G1, 705 G1, 800 G1 , HP Pro 3500 , HP ProDesk 400 G1, 405 G1, 490 G1, 600 G1 , HP Compaq 6300 Pro, 6305 Pro, Elite 8300
