Product
Brand
Hypertec 4GB DIMM 240-pin DDR3 Memory Module
Quicklinx: 93KGWS00 Mfr#: AT025AA-HY
Hypertec - DDR3 - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - 1.5 V - unbuffered - non-ECC - for HP 6000 Pro, Elite 8000, Elite 8100; Pro 2110, 3115, 3120, 3125, 3130
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
Voltage
1.5 V
HP AT025AA
4 GB
Upgrade Type
System specific
HP AT025AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
HP Pro 2110, 3115, 3120, 3125, 3130 , HP Compaq 6000 Pro, Elite 8000, Elite 8100
