Product
Brand
Hypertec 4GB DDR3 1066Mhz SODIMM 256X8 Memory Module
Quicklinx: 8SY2WS00 Mfr#: HYS31025684GBOE
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hypertec - DDR3 - 4 GB - SO-DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Dual rank, unbuffered
Voltage
1.5 V
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Non-ECC
Chips Organization
256 x 8
Voltage
1.5 V
