Hypertec 2GB SODIMM 204-pin DDR3 Memory Module
Quicklinx: 93JMWS00 Mfr#: AT912AA-HY
Hypertec - DDR3 - 2 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered - non-ECC - for HP 45X; EliteBook 25XX, 27XX, 84XX, 85XX, 87XX; Envy DV6, DV7; Mini 100; Pavilion dv6, dv7
Hypertec Legacy - DDR3 - module - 2 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
HP AT912AA
HP 3115, 420, 425, 450, 455, 620, 625, 630, 635; EliteBook 2170, 25XX, 27XX, 84XX, 85XX, 87XX; ENVY Laptop dv6, dv7; Mini 100, 5103; Mobile Thin Client 4320; Pavilion Laptop dv6, dv7; ProBook 43XX, 44XX, 45XX, 47XX, 53XX, 6360, 64XX, 65XX
2 GB
Upgrade Type
System specific
HP AT912AA
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
HP EliteBook 2570p, 2760p, 8440p Notebook, 8440w Mobile Workstation, 8460p Notebook, 8460w Mobile Workstation, 8470p Notebook, 8470w Mobile Workstation, 8540p Notebook, 8540w Mobile Workstation, 8560p Notebook, 8560w Mobile Workstation, 8570w Mobile Workstation, 8740w Mobile Workstation, 8760w Mobile Workstation, 8770w Mobile Workstation , HP ENVY Laptop dv6-7200ea, dv6-7200sa, dv6-7201eg, dv6-7202eg, dv6-7202ss, dv6-7203es, dv6-7210us, dv6-7214nr, dv6-7214tx, dv6-7215nr, dv6-7220us, dv6-7222nr, dv6-7223nr, dv6-7227nr, dv6-7227sa, dv6-7228nr, dv6-7229nr, dv6-7240sg, dv6-7250ca, dv6-7251eo, dv6-7252eo, dv6-7254eo, dv6-7267cl, dv6-7276ez, dv6-7280la, dv6-7280sf, dv6-7290sf, dv6-7300ea, dv6-7300sa, dv6-7302eo, dv6-7370sf, dv7-7201eg, dv7-7202eg, dv7-7202ss, dv7-7203ea, dv7-7205tx, dv7-7212nr, dv7-7215sg, dv7-7230us, dv7-7240us, dv7-7243nr, dv7-7250us, dv7-7252eo, dv7-7259nr, dv7-7270ca, dv7-7290eb, dv7-7292eo, dv7-7299ef, dv7-7299sf , HP Mini 100e Education Edition , HP Pavilion Laptop dv6-2137el, dv6-3008et, dv6-3019wm, dv6-3025et, dv6-3035et, dv6-3101et, dv6-3102et, dv6-3104et, dv6-3105et, dv6-3107et, dv6-3112st, dv6-3113et, dv6-3120et, dv6-3320et, dv6-3340et, dv6-6186nr, dv6-6b31eo, dv6-6b48nr, dv6-6c11sz, dv6-6c82sl, dv6-7000sy, dv6-7001em, dv6-7002ed, dv6-7003ax, dv6-7003sm, dv6-7003sp, dv6-7003ss, dv6-7004es, dv6-7004ss, dv6-7006ed, dv6-7009ss, dv6-7010eo, dv6-7010ss, dv6-7010us, dv6-7011eo, dv6-7013cl, dv6-7014nr, dv6-7020sg, dv6-7020us, dv6-7024eo, dv6-7024nr, dv6-7028tx, dv6-7029tx, dv6-7029wm, dv6-7030sz, dv6-7030tx, dv6-7031tx, dv6-7040sb, dv6-7041tx, dv6-7050ca, dv6-7050eb, dv6-7050ez, dv6-7050sb, dv6-7050sw, dv6-7051sa, dv6-7053ea, dv6-7054sa, dv6-7055sa, dv6-7060sf, dv6-7061sa, dv6-7062sf, dv6-7063sa, dv6-7070el, dv6-7070sf, dv6-7070sw, dv6-7080eb, dv6-7082eg, dv6-7084la, dv6-7086la, dv6-7090ef, dv6-7090el, dv6-7090sf, dv6-7099eo, dv6-7114nr, dv6-7115nr, dv7-3169wm, dv7-4069wm, dv7-4197cl, dv7-6102er
