Hypertec - DDR3 - 2 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered - non-ECC - for Lenovo ThinkCentre A63; A70; A70z; M58; M58p; M90; M90p
- Hypertec Legacy - DDR3 - module - 2 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1066 MHz (PC3-8500)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- IBM 45J5435
- Designed For
- Lenovo ThinkCentre A63; A70; A70z; M58; M58p; M90; M90p
- Capacity
- 2 GB
- Upgrade Type
- System specific
- IBM 45J5435
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Lenovo ThinkCentre A63 4013, 4478, 5043, 5237, 5393, 5526, 6674 , Lenovo ThinkCentre A70 0864, 0889, 7099, 7844 , Lenovo ThinkCentre A70z 0401, 2565 , Lenovo ThinkCentre M58 4086, 4099, 6138, 6239, 6258, 6302, 6303, 7354, 7355, 7360, 7373, 7627, 7628, 7638, 7639, 8910, 9728, 9960 , Lenovo ThinkCentre M58p 3063, 3285, 4084, 4087, 4088, 4138, 6137, 6138, 6209, 6234, 7188, 7220, 7357, 7358, 7483, 7484, 7628, 7630, 7635, 9964, 9965 , Lenovo ThinkCentre M90 3026, 3029, 3039, 3054, 3137, 3139, 3149, 3219, 3245, 3246, 3282, 3319, 3349, 3394, 3421, 3491, 3544, 3652, 3699, 3769, 3878, 3934, 4972, 4992, 5132, 5206, 5261, 5267, 5297, 5325, 5384, 5391, 5450, 5474, 5475, 5485, 5492, 5498, 5547, 5554, 5567, 5852 , Lenovo ThinkCentre M90p 3026, 3029, 3039, 3054, 3137, 3139, 3149, 3219, 3269, 3282, 3319, 3349, 3394, 3421, 3544, 3627, 3652, 3699, 3769, 3878, 3934, 4972, 4992, 5132, 5206, 5261, 5267, 5297, 5325, 5384, 5391, 5450, 5475, 5492, 5498, 5536, 5547, 5554, 5567, 5852, 5864
