Hypertec 2GB DIMM 240-pin DDR3 Memory Module
Quicklinx: 93JYWS00 Mfr#: 45J5435-HY
Hypertec - DDR3 - 2 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered - non-ECC - for Lenovo ThinkCentre A63; A70; A70z; M58; M58p; M90; M90p
Hypertec Legacy - DDR3 - module - 2 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Unbuffered
IBM 45J5435
2 GB
Upgrade Type
System specific
IBM 45J5435
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
1066 MHz (PC3-8500)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Lenovo ThinkCentre A63 4013, 4478, 5043, 5237, 5393, 5526, 6674 , Lenovo ThinkCentre A70 0864, 0889, 7099, 7844 , Lenovo ThinkCentre A70z 0401, 2565 , Lenovo ThinkCentre M58 4086, 4099, 6138, 6239, 6258, 6302, 6303, 7354, 7355, 7360, 7373, 7627, 7628, 7638, 7639, 8910, 9728, 9960 , Lenovo ThinkCentre M58p 3063, 3285, 4084, 4087, 4088, 4138, 6137, 6138, 6209, 6234, 7188, 7220, 7357, 7358, 7483, 7484, 7628, 7630, 7635, 9964, 9965 , Lenovo ThinkCentre M90 3026, 3029, 3039, 3054, 3137, 3139, 3149, 3219, 3245, 3246, 3282, 3319, 3349, 3394, 3421, 3491, 3544, 3652, 3699, 3769, 3878, 3934, 4972, 4992, 5132, 5206, 5261, 5267, 5297, 5325, 5384, 5391, 5450, 5474, 5475, 5485, 5492, 5498, 5547, 5554, 5567, 5852 , Lenovo ThinkCentre M90p 3026, 3029, 3039, 3054, 3137, 3139, 3149, 3219, 3269, 3282, 3319, 3349, 3394, 3421, 3544, 3627, 3652, 3699, 3769, 3878, 3934, 4972, 4992, 5132, 5206, 5261, 5267, 5297, 5325, 5384, 5391, 5450, 5475, 5492, 5498, 5536, 5547, 5554, 5567, 5852, 5864
