Your basket is empty
Hypertec 2GB DIMM 240-pin DDR2 Memory Module
Quicklinx: 93GTWS00 Mfr#: AH060AA-HY
Hypertec provide PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory to Storage; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provide a complete solution to your needs.
Hypertec have spent over 19 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hypertec - DDR2 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Unbuffered
HP AH060AA
HP Business Desktop dc5700, dc5750, dc5800, dc5850, dc7600, dc7800, dc7900, dx2040, dx2200, dx2250, dx2300, dx2310, dx2355, dx2390, dx2400, dx2420, dx2450, dx2480, dx2710, dx2810, dx7300, dx7400, dx7480, dx7500, rp5700; Point of Sale System ap5000, rp3000, rp5700; HPE Compaq Business Desktop dc7700
2 GB
Upgrade Type
System specific
HP AH060AA
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP Point of Sale System ap5000, rp3000, rp5700 , HP Compaq Business Desktop dc5100, dc5700, dc5750, dc5800, dc5850, dc7600, dc7800, dc7900, dx2040, dx2200, dx2250, dx2300, dx2310, dx2355, dx2390, dx2400, dx2420, dx2450, dx2480, dx2710, dx2810, dx6120, dx7300, dx7400, dx7480, dx7500, rp5700 , HPE Compaq Business Desktop dc7700
