Hypertec - DDR2 - 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered - non-ECC - for Lenovo J200; J205; S200; S205; ThinkCentre A55; A57; A60; A61; A62; M55; M57; M58
- Hypertec Legacy - DDR2 - module - 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- IBM 73P4985
- Limited lifetime warranty
- Capacity
- 2 GB
- Upgrade Type
- System specific
- IBM 73P4985
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
