Your basket is empty
Hypertec 2GB DDR3 PC3-10600 1333Mhz Memory Module
Quicklinx: 93G6WS00 Mfr#: HYU31312882GB
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hypertec Legacy - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Chips Organization
128 x 8
