Your basket is empty
Hypertec 2GB DDR3 DIMM 240-pin 1333 MHz/PC3-10600 unbuffered non-ECC
Quicklinx: BGYRWS00 Mfr#: 497157-D88-HY
Type: DDR3 SDRAM
Capacity: 2GB
Connection: DIMM 240-pin
Speed: 1333MHz
Data Integrity: Non-ECC
£17.56 ex VAT
£21.07 inc VAT
Hypertec - DDR3 - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered - non-ECC
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
HP 497157-D88
2 GB
Upgrade Type
System specific
HP 497157-D88
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Hypertec 2GB DDR3 DIMM 240-pin 1333 MHz/PC3-10600 unbuffered non-ECC Bundle deal on Hypertec 2GB DDR3 DIMM 240-pin 1333 MHz/PC3-10600 unbuffered non-ECC
£33.57
saving £8.87
Type: DDR3 SDRAM
Capacity: 2GB
Speed: 1333MHz
Registered/Buffered: Unbuffered
Standard: PC3-10600
Price Range Ex VAT: 0 - 50
