Your basket is empty
Hypertec 2GB DDR2 533 MHz DIMM Memory
Quicklinx: 8L9CWS00 Mfr#: HYU24212882GBOE
Hypertec - DDR2 - 2 GB - DIMM 240-pin - 533 MHz / PC2-4200 - unbuffered - non-ECC
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
533 MHz ( PC2-4200 )
Unbuffered
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Chips Organization
128 x 8
Compatible Slots
1 x memory - DIMM 240-pin
