Product
Brand
Hypertec 16GB DDR3 DIMM 240-pin 1333 MHz/PC3-10600 1.35 V - Registered - ECC
Quicklinx: C9QRWS00 Mfr#: A6996789-HY
Hypertec - DDR3 - 16 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - 1.35 V - registered - ECC - for Dell PowerEdge C8220, R320, R420, T320; Precision T5500, T7500
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Dual rank, Low Voltage, registered
Voltage
1.35 V
DELL A6996789
Dell PowerEdge C1100, C2100, C6100, C6105, C6145, C6220, C8220, M420, M520, M610, M620, M710, M820, M910, M915, R210, R320, R410, R415, R420, R510, R515, R520, R610, R620, R710, R715, R720, R815, R820, R910, T320, T410, T420, T610, T620, T710; Precision R5500, T5500, T5600, T7500, T7600
16 GB
Upgrade Type
System specific
DELL A6996789
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
Dell PowerEdge C1100, C2100, C6100, C6105, C6145, C6220, C8220, C8220 Compute Sled, C8220X, M420, M520, M610, M610x, M620, M710, M710HD, M820, M910, M915, R210 II, R320, R410, R415, R420, R420xr, R510, R515, R520, R610, R620, R710, R715, R720, R720xd, R815, R820, R910, T320, T410, T420, T610, T620, T710 , Dell Precision R5500, T5500, T5600, T5600 Advanced, T5600 Base, T5600 Essential, T7500, T7600, T7600 Advanced, T7600 Base, T7600 Essential
