Your basket is empty
Hypertec 1-GB DDR Synch Dram PC2700 (333-MHz) Non ECC Memory Module
Quicklinx: 8FLCWS00 Mfr#: HYU1276481GBOE
Type: DDR SDRAM
Capacity: 1GB
Connection: DIMM 184-PIN
Speed: 333MHz
Data Integrity: Non-ECC
£10.56 ex VAT
£12.67 inc VAT
Hypertec - DDR - 1 GB - DIMM 184-PIN - 333 MHz / PC2700 - unbuffered - non-ECC
RAM memory
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
333 MHz ( PC2700 )
Unbuffered
1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Speed
333 MHz ( PC2700 )
Non-ECC
Unbuffered
Chips Organization
64 x 8
Compatible Slots
1 x memory - DIMM 184-PIN
Hypertec 1-GB DDR Synch Dram PC2700 (333-MHz) Non ECC Memory Module Bundle deal on Hypertec 1-GB DDR Synch Dram PC2700 (333-MHz) Non ECC Memory Module
£31.75
saving £14.13
Type: DDR SDRAM
Capacity: 1GB
Speed: 333MHz
Registered/Buffered: Unbuffered
Standard: PC2700
Price Range Ex VAT: 0 - 50
