Your basket is empty
Hypertec - DDR3 - 2 GB - DIMM 240-pin
Quicklinx: B3FBWS00 Mfr#: 57Y4390-HY
Type: DDR3 SDRAM
Capacity: 2GB
Connection: DIMM 240-pin
Speed: 1333MHz
Standard: PC3-10600
Hurry, only 1 left in stock!
£8.67 ex VAT
£10.40 inc VAT
Express delivery Order within the next 20 hours for delivery on Monday
Hypertec - DDR3 - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - for Lenovo ThinkCentre Edge 71; ThinkCentre M71; M80; M81; M90; M91; ThinkStation E20; E30
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Speed
1333 MHz ( PC3-10600 )
Lenovo ThinkCentre A63; ThinkCentre Edge 71; ThinkCentre M71e; M80; M81; M90; M90p; M91; M91p; ThinkStation E20; E30
2 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Compatible Slots
Memory - DIMM 240-pin
Lenovo ThinkCentre A63 , Lenovo ThinkCentre Edge 71 , Lenovo ThinkCentre M71e , Lenovo ThinkCentre M80 , Lenovo ThinkCentre M81 , Lenovo ThinkCentre M90 3026, 3029, 3039, 3054, 3137, 3139, 3149, 3219, 3245, 3246, 3282, 3319, 3349, 3394, 3421, 3491, 3544, 3652, 3699, 3769, 3878, 3934, 4972, 4992, 5206, 5261, 5267, 5297, 5325, 5384, 5391, 5450, 5474, 5485, 5492, 5498, 5547, 5554, 5567, 5852 , Lenovo ThinkCentre M90p 3026, 3029, 3039, 3054, 3137, 3139, 3149, 3219, 3269, 3282, 3319, 3349, 3394, 3421, 3544, 3627, 3652, 3699, 3769, 3878, 3934, 4972, 4992, 5206, 5261, 5267, 5297, 5325, 5384, 5391, 5450, 5492, 5498, 5536, 5547, 5554, 5567, 5852, 5864 , Lenovo ThinkCentre M91 4514, 4517 , Lenovo ThinkCentre M91p 4466, 4480, 4512, 4513, 4518, 4524, 7005, 7021, 7033, 7034, 7052, 7072 , Lenovo ThinkStation E20 , Lenovo ThinkStation E30
Hypertec - DDR3 - 2 GB - DIMM 240-pin Bundle deal on Hypertec - DDR3 - 2 GB - DIMM 240-pin
£24.99
saving £8.65
Type: DDR3 SDRAM
Capacity: 2GB
Speed: 1333MHz
Standard: PC3-10600
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
