Hynix 120GB SL308 2.5" SATA 6Gb/s SSD
Quicklinx: C9VNWS00 Mfr#: HFS120G32TND-N1A2A
SK hynix SL308 2.5" SSD
A multi-tasking product boasting fast booting in various PCs, excellent durability, and outstanding speed.
A Superior PC Experience
In addition to enhanced performance, an SK hynix SL308 upgrade promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. With no moving parts, SSDs provide peace of mind with their superior durability and reliability.
TRIM Support
The SK hynix SL308 offers native TRIM support featured in Windows 7 and up. Designed to maintain the performance of SSD at an optimal level over the lifetime of the drive, TRIM functions by actively deleting invalid data from the SSD’s memory cells to ensure that write operations perform at full speed. Since a memory block must be erased before it can be re-programmed, TRIM improves performance by pro-actively erasing pages containing invalid data, allowing the SSD to write new data without first having to perform a time-consuming erase command.
S.M.A.R.T. Technology
The SK hynix SL308 adopts Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.) which enables the PC to predict the future failure of hard disk drives. Through the SMART system, hard disk drives incorporate a suite of advanced diagnostics that monitor the internal operations of a drive and provide an early warning for many types of potential problems. When a potential problem is detected, the hard drive can be repaired or replaced before any data is lost or damaged.
SK Hynix SL308 - SSD - 120 GB - SATA
Solid state drive - internal
120 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA
Secure Erase function, upgradable firmware, S.M.A.R.T.
69.85 mm x 100 mm x 7 mm
60 g
3-year warranty
120 GB
2.5"
SATA
69.85 mm
100 mm
7 mm
60 g
Performance
SSD Endurance
75 TB
Internal Data Rate
560 MBps (read) / 460 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
83000 IOPS
Reliability
MTBF
1,500,000 hours
Recoverable Errors
1 per 10^15
Expansion & Connectivity
Compatible Bay
2.5"
Power Consumption
2.3 Watt (read) , 2 Watt (write) , 50 mW (idle)
TUV, VCCI, BSMI, FCC, RoHS, KCC, WEEE, cULus, China RoHS, RCM
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (operating)
20 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
