Huawei Simfree 150MB 4G Wifi Hotspot
Quicklinx: CY2CWS00 Mfr#: E5577CS-321
Marketing description is not available.
Huawei E5577CS-321 - mobile hotspot - 4G LTE
Mobile hotspot - USB
External
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSDPA, HSUPA, HSPA, HSPA+, LTE, DC-HSPA+
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n - 300 Mbps
1500 mAh - up to 6 hrs
Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows 7 / 8 / 8.1
9.68 cm x 5.8 cm x 1.35 cm
82 g
Mobile hotspot
External
Built-in Devices
Status LCD, 128 MB flash
Modem
Bus
USB
Wireless
128 MB
Max Transfer Rate
150 Mbps
Antenna
Internal
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, DHCP, DNS
Firewall protection, NAT support, ALG support, MAC address filtering, IP address filtering, firmware upgradable, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID, DNS relay
Supported Flash Memory Cards
microSD
1 x micro-USB
SIM Card Supported
1
1 x USB cable
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Plug and Play
3.5 Watt
9.68 cm
5.8 cm
1.35 cm
82 g
35 °C
5 - 95% (non-condensing)
