WIDER VIEW, COMFORTABLE GRIP
The HUAWEI FullView Display features a striking 5.65-inch 2.5D glass screen that reflects vivid, true-to-life colours. The wider screen does not mean a larger body though, the thin, lightweight HUAWEI P smart fits easily in the palm of your hand.
SMART SPLIT SCREEN
The Smart Split Screen lets you run two apps side by side at the touch of a button. So when you get an important email or message while streaming TV or a movie on your HUAWEI P smart, you don't need to pause the fun.
DUAL CAMERAS, ONE AMAZING SHOT
High-spec 13MP + 2MP Dual Cameras mean top quality images at the tap of the screen. The large aperture lenses let in more light for rich, detailed, true-to-life photographs, while the Dual Camera enables perfect shallow depth-of-field bokeh shots.
HANDS-FREE SELFIE
It's never been easier to capture the moment. The HUAWEI P smart's gesture-shot function lets you take selfies and groufies with a simple wave of your hand.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Wide view, ergonomic grip
The Huawei FullView Display integrates a stunning 5.6" 2.5D glass screen that reflects vivid and realistic colors. But wider screen doesn't mean bulkier body, because the slim and ultra-light Huawei P smart easily fits in the palm of your hand. -
Two cameras, one cover shot
The 13MP + 2MP dual camera delivers high-quality images with just a touch. The wide lens aperture allows you to capture even more light for sharp, vivid and detail-rich shots, while the dual camera enables photos with a beautiful bokeh effect even with shallow depth of field. -
Smart Beauty
Using the Face Beauty algorithm, the 8 MP front-facing camera detects all the features of your face and adds the optimal amount of filters, for selfies to share! -
Green light for selfies
Capturing the moment has never been easier. With the Huawei P smart you can take selfies and group selfies with just a wave of your hand. -
Share on the fly
Huawei's share function transfers files between two Huawei phones in a snap without the need for internet or manual connection. -
Dual Bluetooth connection
HUAWEI P smart supports up to two Bluetooth devices at the same time. So you can connect to your car audio system and receive calls on your Bluetooth headset at the same time.
- Huawei P Smart - golden - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- LCD display - 2160 x 1080 pixels - 5.65" - 428 ppi - TFT
- Processor
- Hisilicon Kirin 659 2.36 GHz (8-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Android 8.0 Oreo with HUAWEI Emotion UI 8.0
- Main Camera
- 13 Megapixel focus: automatic
- Second Camera
- 2 Megapixel
- Front Camera
- 8 Megapixel f/2.0
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- Wi-Fi, NFC, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Golden
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 72.05 mm x 7.45 mm x 150.1 mm
- 143 g
- Specific Absorption Rate (SAR)
- 1.27 W/kg (head) , 0.99 W/kg (body)
- Product Type
- Smartphone
- Form Factor
- Touch
- 72.05 mm
- 7.45 mm
- 150.1 mm
- 143 g
- Body Colour
- Golden
- SAR Value
- 0.99 W/kg (body), 1.27 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 8.0 Oreo
- User Interface
- HUAWEI Emotion UI 8.0
- Navigation
- GPS, A-GPS, GLONASS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 3, Band 7, Band 8, Band 20
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD
- IEEE 802.11b/g/n, NFC, Bluetooth 4.2
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Ambient light sensor, proximity sensor, digital compass, gravity sensor
- Security Devices
- Android Enterprise Recommended
- Additional Features
- Dual noise reduction microphones, Huawei Share, Split Screen
- Clock Speed
- 2.36 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.0
- Special Effects
- Smart beauty
Main Camera
- Sensor Resolution
- 13 Megapixel
- Focus Adjustment
- Automatic
- Special Effects
- Depth of field, Bokeh effect, Smart beauty
- Light Source
- Flash
Second Camera
- Sensor Resolution
- 2 Megapixel
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 5.65"
- Display Resolution
- Pixel Density
- 428 ppi
- 2.5D Glass, FullView Display
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Included Accessories
- Headset, screen protection film, USB cable, power adapter, SIM card removal tool
