The Huawei P Smart offers high-performance, advanced software wrapped in stylish hardware.
Capture stunning photos with the 13MP Dual Camera and view them on the striking 5.65-inch FullView Display. The FullView Display gives you have a wider screen without having a larger phone, so the thin and lightweight Huawei P Smart fits easily into the palm of your hand.
With a wider screen come added features, such as Smart Split Screen which lets you run two apps side-by-side. So while you're streaming a movie or just watching a video clip, you can quickly check your email without having to pause the fun!
Wide view, ergonomic grip
The Huawei FullView Display integrates a stunning 5.6" 2.5D glass screen that reflects vivid and realistic colors. But wider screen doesn't mean bulkier body, because the slim and ultra-light Huawei P smart easily fits in the palm of your hand. -
Two cameras, one cover shot
The 13MP + 2MP dual camera delivers high-quality images with just a touch. The wide lens aperture allows you to capture even more light for sharp, vivid and detail-rich shots, while the dual camera enables photos with a beautiful bokeh effect even with shallow depth of field. -
Smart Beauty
Using the Face Beauty algorithm, the 8 MP front-facing camera detects all the features of your face and adds the optimal amount of filters, for selfies to share! -
Green light for selfies
Capturing the moment has never been easier. With the Huawei P smart you can take selfies and group selfies with just a wave of your hand. -
Share on the fly
Huawei's share function transfers files between two Huawei phones in a snap without the need for internet or manual connection. -
Dual Bluetooth connection
HUAWEI P smart supports up to two Bluetooth devices at the same time. So you can connect to your car audio system and receive calls on your Bluetooth headset at the same time.
- Huawei P Smart - black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- LCD display - 2160 x 1080 pixels - 5.65" - 428 ppi - TFT
- Processor
- Hisilicon Kirin 659 2.36 GHz (8-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Android 8.0 Oreo with HUAWEI Emotion UI 8.0
- Main Camera
- 13 Megapixel focus: automatic
- Second Camera
- 2 Megapixel
- Front Camera
- 8 Megapixel f/2.0
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- Wi-Fi, NFC, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Black
- 72.05 mm x 7.45 mm x 150.1 mm
- 143 g
- Specific Absorption Rate (SAR)
- 1.27 W/kg (head) , 0.99 W/kg (body)
- Product Type
- Smartphone
- Form Factor
- Touch
- 72.05 mm
- 7.45 mm
- 150.1 mm
- 143 g
- Body Colour
- Black
- SAR Value
- 0.99 W/kg (body), 1.27 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 8.0 Oreo
- User Interface
- HUAWEI Emotion UI 8.0
- Navigation
- GPS, A-GPS, GLONASS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 3, Band 7, Band 8, Band 20
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD
- IEEE 802.11b/g/n, NFC, Bluetooth 4.2
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Ambient light sensor, proximity sensor, digital compass, gravity sensor
- Security Devices
- Android Enterprise Recommended
- Additional Features
- Dual noise reduction microphones, Huawei Share, Split Screen
- Clock Speed
- 2.36 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.0
- Special Effects
- Smart beauty
Main Camera
- Sensor Resolution
- 13 Megapixel
- Focus Adjustment
- Automatic
- Special Effects
- Depth of field, Bokeh effect, Smart beauty
- Light Source
- LED light
Second Camera
- Sensor Resolution
- 2 Megapixel
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 5.65"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 428 ppi
- 2.5D Glass, FullView Display
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Technology
- Lithium polymer
- Capacity
- 3000 mAh
- Included Accessories
- USB cable, power adapter, SIM card removal tool, screen protector
