Huawei MediaPad T5 Lite 10" 32GB - Black
Quicklinx: FTDWWS00 Mfr#: 53010PTL
The HUAWEI MediaPad T5 is an eye-catching tablet with a premium, refined design. Its symmetrical metal body is crafted with care and is sleek and lightweight enough to be conveniently portable and easy to hold.
  • Stunning 1080p Full HD display
    The Huawei MediaPad T5 comes with a stunning 25.65 cm (10.1") display (1920 x 1200 resolution) that delivers excellent detail. The 16:10 aspect ratio makes it perfect for watching movies or TV shows and browsing websites.
  • Dual speakers: immersive sound
    Dual speakers produce high-quality, robust audio for your favorite music. The Huawei Histen audio technology makes sound richer, giving you an immersive cinematic experience.
  • Powerful processor: blistering performance
    The octa-core processor with a main frequency of up to 2.36 GHz gives you great performance while consuming less power.
  • Eye-comfort mode: eye strain relief
    Eye-comfort mode reduces harmful blue light to create healthy reading conditions for you and your family.
HUAWEI MediaPad T5 - tablet - Android 8.0 (Oreo) - 32 GB - 10.1"
Tablet
Operating System
Android 8.0 (Oreo)
Display
10.1" IPS - 1920 x 1200 (224 ppi) - Multi-Touch
Kirin 659 (8-core)
Storage
32 GB
RAM
3 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Rear Camera
5 Megapixel
Front Camera
2 Megapixel
Navigation System
GPS/GLONASS/BeiDou
USB host
24.3 cm x 0.78 cm x 16.4 cm
460 g
Tablet
Operating System
Android 8.0 (Oreo)
Display
10.1" IPS
Resolution
Touchscreen
Multi-Touch
Kirin 659
Number of Cores
8-core
Storage
32 GB
RAM
3 GB
microSD
Max Supported Capacity
256 GB
Communications
Security Protocols & Features
WEP, WPA, WPA2, Wi-Fi Direct
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP)
Rear Camera
Sensor Resolution
5 Megapixel
Still Image Resolutions
2592 x 1944
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS/GLONASS/BeiDou
Multimedia
Audio
Microphone, stereo speakers
Software
Preloaded Software
Huawei Emotion UI 8.0
Expansion and Connectivity
1 x Micro-USB
USB Host
5100 mAh
Standby Time
680 h
Run Time Details
Audio playback: up to 68 hour(s) , Video playback: up to 8.9 hour(s) , Web browsing over Wi-Fi: up to 7.5 hour(s) , Standby time: up to 680 hour(s)
Recharge Time
6 hour(s)
Sensors
Gravity sensor
Mobile Transfer Protocol (MTP)
Power adapter
USB cable
24.3 cm
0.78 cm
16.4 cm
460 g
