Product
Huawei MediaPad T3 8 WiFi Space Gray
Quicklinx: CZVJWS00 Mfr#: 53018680
Operating System: Android 7.0 (Nougat)
Processor: MSM8917
Screen Size: 8in
RAM: 2GB
23 in stock
£99.16 ex VAT
£118.99 inc VAT
This tablet is fast processing thanks to the 1.2 GHz dual core, HSPA+ and Wi-Fi high speed wireless supported, powered by the highly-rated Android 3.2 operating system. And it's thin, high-definition screen, with multi-touch activation.
  • Strength of design in an elegant package
    Strong things can come in slim packages. HUAWEI MediaPad T3 delivers power and smooth usability while being thin and weighing little. Housed in this elegant case is everything you need to enjoy a truly modern online experience.
  • Sleek solid style
    Made from a solid piece of sleek anodized aluminum, the feeling of this device exudes sleek strength and refined style. The sleek design and the raw power of this device are perfectly captured in the tastefully polished metallic finish.
  • Joy, that lasts
    HUAWEI MediaPad T3 delivers long-lasting enjoyment, even with heavy use. The improved battery keeps the lights on for longer, giving you an unrushed, uninterrupted experience.
  • Take your family along
    Smart app access and content control allows you to let others use your device in a way, that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
HUAWEI MediaPad T3 - tablet - Android 7.0 (Nougat) - 16 GB - 8"
Tablet
Operating System
Display
8" IPS - 1280 x 800
Qualcomm MSM8917 (Quad-Core)
Processor Clock Speed
1.4 GHz
Storage
16 GB
RAM
2 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.1
Camera
5 Megapixel (rear), 2 Megapixel (front)
HD Video Recording
1080p
Navigation System
GPS/GLONASS/BeiDou
USB host
12.47 cm x 0.8 cm x 21.11 cm
350 g
Grey
United Kingdom
Environmental Standards
ENERGY STAR Qualified
Tablet
Operating System
Display
8" IPS
Resolution
1280 x 800
Motion Eye Care
Qualcomm MSM8917
1.4 GHz
Number of Cores
Quad-Core
Storage
16 GB
RAM
2 GB
Max Supported Capacity
128 GB
Communications
Security Protocols & Features
WEP, WPA, WPA2, Wi-Fi Direct
Bluetooth Profiles
Hands-Free Profile (HFP), Object Push Profile (OPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Camera
Resolution (MP)
Still Image Resolutions
1600 x 1200, 2592 x 1944
Video Resolutions
720p, 1080p
Frame Rate
30 frames per second
HD Video Recording
1080p
Navigation System
Receiver
GPS/GLONASS/BeiDou
Multimedia
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, OGG, M4A, MID
Supported Digital Video Standards
DivX, AVI, MKV, MOV, 3GP, TS, FLV, 3G2, M4V, WEBM, MP4
Audio
Microphone, speaker
Software
Preloaded Software
Huawei Emotion UI 5.1
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x headset , 1 x Micro-USB
USB Host
4800 mAh
Grey
Case Material
Metal
Sensors
Gravity sensor
Super Wide Sound (SWS) 3.0
Power adapter
USB cable
United Kingdom
12.47 cm
0.8 cm
21.11 cm
350 g
ENERGY STAR Certified
Huawei MediaPad T3 8 WiFi Space Gray Bundle deal on Huawei MediaPad T3 8 WiFi Space Gray
£198.92
Processor: MSM8917
Screen Size: 8in
RAM: 2GB
Brand: Huawei
Price Range Ex VAT: 50 - 100
