Huawei Mediapad T3 8" 16GB Lte Tablet
Quicklinx: FFQHWS00 Mfr#: 53018671
See the world in crisp and vivid color with the HUAWEI MediaPad T3 8-inch IPS HD display. This high-resolution display will bring your watching experience to another level, while providing comfort for your grip, and for your eyes. The blue-light filter and low-light display modes make sure, that you don’t tire your eyes.
  • Strength of design in an elegant package
    Strong things can come in slim packages. HUAWEI MediaPad T3 delivers power and smooth usability while being thin and weighing little. Housed in this elegant case is everything you need to enjoy a truly modern online experience.
  • Sleek solid style
    Made from a solid piece of sleek anodized aluminum, the feeling of this device exudes sleek strength and refined style. The sleek design and the raw power of this device are perfectly captured in the tastefully polished metallic finish.
  • Joy, that lasts
    HUAWEI MediaPad T3 delivers long-lasting enjoyment, even with heavy use. The improved battery keeps the lights on for longer, giving you an unrushed, uninterrupted experience.
  • Take your family along
    Smart app access and content control allows you to let others use your device in a way, that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
HUAWEI MediaPad T3 - tablet - Android 7.0 (Nougat) - 16 GB - 8" - 4G
Tablet
Operating System
Display
8" IPS - 1280 x 800
Qualcomm MSM8917 (Quad-Core)
Processor Clock Speed
1.4 GHz
Storage
16 GB
RAM
2 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Cellular Technology
4G
Cellular Protocols
GSM, UMTS, TD-SCDMA, LTE, FDD LTE, TDD LTE
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.1
Rear Camera
5 Megapixel
Front Camera
2 Megapixel
Navigation System
GPS/GLONASS/BeiDou
USB host
21.107 cm x 0.735 cm x 12.465 cm
350 g
Grey
United Kingdom
Environmental Standards
ENERGY STAR Qualified
Tablet
Operating System
Display
8" IPS
Resolution
1280 x 800
Motion Eye Care
Qualcomm MSM8917
1.4 GHz
Number of Cores
Quad-Core
Storage
16 GB
RAM
2 GB
Max Supported Capacity
128 GB
Communications
Cellular Technology
4G
Cellular Protocols
Security Protocols & Features
WEP, WPA, WPA2, Wi-Fi Direct
Bluetooth Profiles
Hands-Free Profile (HFP), Object Push Profile (OPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
Sensor Resolution
5 Megapixel
Still Image Resolutions
1600 x 1200, 2592 x 1944
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS/GLONASS/BeiDou
Multimedia
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, OGG, M4A, MID
Supported Digital Video Standards
DivX, AVI, MKV, MOV, 3GP, TS, FLV, 3G2, M4V, WEBM, MP4
Audio
Microphone, speaker
Software
Preloaded Software
Huawei Emotion UI 5.1
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x headset , 1 x Micro-USB
USB Host
4800 mAh
Grey
Case Material
Metal
Sensors
Gravity sensor
Wi-fi hotspot router, Mobile Transfer Protocol (MTP), Super Wide Sound (SWS) 3.0
Power adapter, SIM card ejection tool
USB cable
United Kingdom
21.107 cm
0.735 cm
12.465 cm
350 g
ENERGY STAR Certified
