See the world in crisp and vivid color with the HUAWEI MediaPad T3 7-inch IPS HD display. This high-resolution display will bring your watching experience to another level, while providing comfort for your grip, and for your eyes. The blue-light filter and low-light display modes make sure, that you don’t tire your eyes.
Strength of design in an elegant package
Strong things can come in slim packages. HUAWEI MediaPad T3 delivers power and smooth usability while being thin and weighing little. Housed in this elegant case is everything you need to enjoy a truly modern online experience. -
Sleek solid style
Made from a solid piece of sleek anodized aluminum, the feeling of this device exudes sleek strength and refined style. The sleek design and the raw power of this device are perfectly captured in the tastefully polished metallic finish. -
Joy, that lasts
HUAWEI MediaPad T3 delivers long-lasting enjoyment, even with heavy use. The improved battery keeps the lights on for longer, giving you an unrushed, uninterrupted experience. -
Take your family along
Smart app access and content control allows you to let others use your device in a way, that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
