Huawei MediaPad T3 10" Lite 16GB LTE - Space Grey
Quicklinx: DCSHWS00 Mfr#: 53018668
Touch the power of brilliant design with your HUAWEI MediaPad T3 10. See the world in vibrant colour through the vivid 9.6 inch display. Feel the quality in the single-piece space-age anodized aluminum body. The HUAWEI MediaPad T3 10 is there for you, day or night. The special low-light and eye protection mode makes sure that you keep the full view of your life, reducing eye strain and helping preserve your natural sleep pattern. Stand out, get out, the HUAWEI MediaPad T3 10 is your loyal companion, day or night. The long-lasting battery will make sure that you have the tools you need, for as long as you need them. Always feel like you're with a trusted friend, with the HUAWEI MediaPad T3 10 EMUI 5.1 operation system, carefully designed for intuitive, easy interaction. Powered by android 7.0, the custom OS of the HUAWEI MediaPad T3 10 is here to make your life easier. Smart app access and content control allows you to let others use your device in a way that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
  • Octa Core 1.4GHz Processor
  • 9.6" Capacitive Screen
  • 1280 x 800 Resolution
  • 16GB Storage
  • Android 7.0 Operating System
  • Clarity with vision
    The MediaPad T3 10 is there for you, day or night. The special low-light and eye protection mode makes sure, that you keep the full view of your life, reducing eye strain and helping preserve your natural sleep pattern.
  • Joy, that lasts
    Stand out, get out, the MediaPad T3 10 is your loyal companion, day or night. The long-lasting battery will make sure, that you have the tools you need, for as long as you need them.
  • Powerful by nature, friendly by design
    Always feel like you’re with a trusted friend, with the MediaPad T3 10, carefully designed for intuitive, easy interaction. The MediaPad T3 10 is here to make your life easier.
  • Take your family along
    Smart app access and content control allows you to let others use your device in a way, that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
HUAWEI MediaPad T3 10 - tablet - Android 7.0 (Nougat) - 16 GB - 9.6" - 4G
Tablet
Operating System
Display
9.6" IPS TFT - 1280 x 800 - Multi-Touch
Qualcomm MSM8917 (Quad-Core)
Processor Clock Speed
1.4 GHz
Storage
16 GB
RAM
2 GB
Supported Flash Memory Cards
microSD
Cellular Technology
4G
Cellular Protocols
GSM, UMTS, TD-SCDMA, LTE, FDD LTE, TDD LTE
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.1
Rear Camera
5 Megapixel focus: automatic
Front Camera
2 Megapixel
Navigation System
GPS/GLONASS/BeiDou
USB host
22.98 cm x 0.795 cm x 15.98 cm
460 g
Grey
United Kingdom
Tablet
Operating System
Display
9.6" IPS TFT
Resolution
1280 x 800
Touchscreen
Multi-Touch
Wi-Fi Direct, Motion Eye Care
Qualcomm MSM8917
1.4 GHz
Number of Cores
Quad-Core
Storage
16 GB
RAM
2 GB
microSD
Max Supported Capacity
128 GB
Communications
Cellular Technology
4G
Cellular Protocols
Security Protocols & Features
WEP, WPA, WPA2
Bluetooth Profiles
Hands-Free Profile (HFP), Object Push Profile (OPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
Sensor Resolution
5 Megapixel
Focus Adjustment
Automatic
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS/GLONASS/BeiDou
Multimedia
Audio
Microphone, speaker
Software
Preloaded Software
Huawei Emotion UI 5.1
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x headset , 1 x Micro-USB
USB Host
4800 mAh
Grey
Sensors
Gravity sensor
Wi-fi hotspot router, Super Wide Sound (SWS) 3.0
Power adapter
Data cable
United Kingdom
22.98 cm
0.795 cm
15.98 cm
460 g
