Excite More Than Your Ears
More than an epic to listen to, the all new HUAWEI FreeBuds 3 is amazing to look at. Inspired by nature, the symmetrically round charging case is a feast for the eyes, and compact to hold or keep in the pocket, bag or anywhere.
Feel the Comfort in Great Sound
HUAWEI FreeBuds 3’s Dolphin Bionic Design fits in your ears for a more comfortable and stable wearing, while delivering the focused sound deeply in your ears. Open-fit design is ergonomically engineered for maximum comfort.
Chipset Revolution: Redefining Bluetooth Connections
Equipped with the world’s 1st certified BT/BLE dual-mode Bluetooth 5.1 SoC, HUAWEI Isochronous Dual Channel transmission technology and a class-leading 356MHz audio processor, the HUAWEI FreeBuds 3 delivers a stable, fast Bluetooth connection, as well as an accurate audio and video synchronization. Games are more fun and videos are more immersive.
Pure Listening with Active Noise Cancellation
ANC Combined with class-leading audio processor delivers precise environment noise reduction that optimizes in real-time, capturing and cancelling background noise as it changes. No matter in the crowded metro or a noisy restaurant, you can still enjoy crystal clear music.
Adjustable ANC Effect
To personalize the ANC effect according to your ear canal and wearing habit, we recommend you to download the AI Life App to adjust its ANC levels.
Always Be Heard
Thanks to the A1 intelligent chipset, HUAWEI FreeBuds 3 can eliminate the background noise during calls and enhance your voice simultaneously. Calls sound like face-to-face conversations.
Bone Sensor, Clear Calling
With the built-in bone voice sensor, HUAWEI FreeBuds 3 can better pick up your voice through bone vibrations so that your voice will be enhanced accordingly to make it clear and stand-out during phone calls while the ambient noise has been reduced.
Aerodynamic Mic Duct Design
Wind noise ruins important calls. The Aerodynamic Mic Duct Design can suppress the wind passing by to reduce wind noise efficiently so you can have clear calls during walking in a windy day, jogging or even riding at 20km/h.
Studio-Quality Sound
The high-precision, high-sensitivity 14mm dynamic driver has been carefully tuned to allow every note to be restored to it's original brilliance. You deserve the better sound.
Booming Bass
A complex bass tube cleverly tucked in each earpiece powers. Louder, stronger, tighter and punchier. It feels like you’re enjoying the music in a studio.
Pop-Open, Instant Pairing
When first pairing HUAWEI FreeBuds 3, simply click on the pop-up window to pair. Subsequent pairing happens automatically. Enjoy your favorite music instantly.
Tap to the Beat
HUAWEI FreeBuds 3’s intuitive controls seamlessly and easily fit into your life. Double tap the right to play / switch music, or the left to turn on / off ANC function. Playback pauses when taken off, and resumes once put back in.
Smart Charging, Stay on the Go
Except for using the traditional USB Type-C charging set, you can simply lay down the case on a wireless charging mat for quick wireless charging, or use HUAWEI smartphone for reverse charging. The fully charged case can support about 4 times of earbuds charging.
Great sound
FreeBuds 3's design fits in your ears for a more comfortable and stable wearing, while delivering the focused sound deeply in your ears. Open-fit design is ergonomically engineered for maximum comfort. -
Redefining Bluetooth connections
FreeBuds 3 deliver a stable, fast Bluetooth connection, as well as an accurate audio and video synchronization. Games are more fun and videos are more immersive. -
Pure listening
ANC combined with an advanced audio processor delivers precise environment noise reduction that optimizes in real-time, capturing and canceling background noise as it changes. -
Always be heard
- Huawei FreeBuds 3 - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Ceramic white
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Controls
- Play/pause, ANC on/off, tap control
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Charging case: 6.09 cm x 6.09 cm x 2.18 cm / 48 g
- 1.78 cm
- 2.04 cm
- 4.15 cm
- 4.5 g
- Ceramic white
- Recommended Use
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Diaphragm
- 14.2 mm
- HUAWEI Kirin A1
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Tracking
- Sensors
- Infrared wear sensor, bone sensor
- Included Accessories
- USB-C charging cable, wireless charging case
- Auto On/Off
- Battery
- Headphone battery rechargeable
- Wireless Charging Standards
- Qi
- Capacity
- 30 mAh
- Run Time (Up To)
- 4 hour(s)
- Run Time Details
- Continuous playback: up to 4 hours
- Recharge Time
- 1 hour(s)
