Huawei B315s-22 Wireless Router WWAN 802.11b/g/n - Desktop
Quicklinx: CNW1WS00 Mfr#: B315S-22
  • IEEE 802.11n
The Huawei B315s-22 is a wireless gateway that integrates LTE and high-speed Ethernet uplink access, which provides users with flexible and diversified data access and voice services.
Huawei B315s-22 - wireless router - WWAN - 802.11b/g/n - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, WCDMA, HSPA, HSPA+, LTE, DC-HSPA+
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, ICMP/IP, PPPoE, ARP, DHCP, DNS
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP
Firewall protection, DMZ port, NAT support, auto-negotiation, ARP support, auto-uplink (auto MDI/MDI-X), ALG support, manageable, MAC address filtering, IPv6 support, URL filtering, Wi-Fi Multimedia (WMM) support, DHCP server, Multiple SSID support, port forwarding, reset button, IPv4 support, port triggering, DNS relay, Wi-Fi Protected Setup (WPS v2)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
AC 120/230 V
Image Colour Disclaimer
The displayed product image may be a different colour
18.6 cm x 4.6 cm x 13.9 cm
275 g
Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows 7 / 8 / 8.1
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
AES, TKIP, WPA-PSK, WPA2-PSK, WEP
Status Indicators
Power, signal strength, WLAN, LAN, WPS, Internet
Communications
Wireless cellular modem
Max Transfer Rate
150 Mbps
IP Telephony
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP
Voice Codecs
G.722, G.729, G.711u, G.711a, G.726
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Antenna: 2 x , Phone line: 1 x RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Expansion Slots
1 (total) / 1 (free) x SIM
External power adapter
AC 120/230 V
12 Watt
1 x network cable
18.6 cm
4.6 cm
13.9 cm
275 g
5 - 95%
