HTC VR-Brille Vive Pro - Full Kit - Violet
Quicklinx: FYY6WS00 Mfr#: 99HANW003-00
£981.72 ex VAT
£1,178.06 inc VAT
Equipped with SteamVR Base Station 2.0, VIVE Pro offers next level immersion with improved tracking - ideal for creating multi-player experiences without disrupting one another.
  • Crossing realities
    VIVE Pro delivers immersion unlike any other: true-to-life precise tracking, ultra-vibrant colors and uber-realistic sounds create a world that transports you to any scene in split seconds. With the highest quality display of any VR headset, VIVE Pro gives life to any realities.
  • Spot every detail
    See the difference with VIVE Pro. The screen panels dazzle the eye and sweep you away into your wildest imagination. Uncompromising, super-rich colors and details bring objects to life like never before.
  • 3D spatial audio
    Hear every world as intended by its creator. The Hi-Res certified HMD and headphones are now integrated with 3D spatial sound to deliver for true-to-life immersive audio. The powerful amplifier is capable of driving high-impedance headphones - creating soundscapes that will change your world. The dual microphones allow for active noise cancellation as well as enabling Alert Mode and Conversation Mode - so you hear your surroundings while being immersed in any realities without the need of taking off the headset.
  • Designed for comfort
    VIVE Pro is engineered from top down for optimized ergonomics. Just place the headset on your face, slide the strap over your head - it's done. The chassis evenly distributes the weight of the device to achieve an optimal center of gravity - creating comfort in VR that is unlike any other.
  • Room-scale just got roomier
    Expand your horizons by adding additional base stations to track even larger interactive room-scale space.
HTC VIVE Pro Full Kit - 3D virtual reality headset
Virtual reality headset
3D Capable
2 microphones
Sensors
Proximity sensor, gyro sensor, G-sensor, IPD sensor
Native Resolution
2880 x 1600 at 90 Hz
Resolution per Eye
3.5" - 1440 x 1600
Field of View
110°
Input Connectors
DisplayPort
DisplayPort 1.2
Display Type
Virtual reality headset / AMOLED
3D Capable
Built-in Devices
2 microphones
Native Resolution
VR Headset
Resolution per Eye
1440 x 1600
Diagonal Size per Eye
3.5"
Field of View
110°
Sensors
Adjustable headband, interpupillary distance adjustment, SteamVR tracking technology, adjustable headphones, adjustable lens distance
Audio
Headphone
USB-C , DisplayPort
Bluetooth interface
Cleaning cloth, link box, face cushion (attached), 2 x earphone hole caps
1 x SuperSpeed USB cable , 1 x DisplayPort cable
DisplayPort 1.2
Microsoft Windows 7, Windows 10, Windows 8.1 or later
Brand: HTC
Price Range Ex VAT: £750 - £1000
