Spectacular sights. Hi-Res sound. Unrivaled immersion.
Crossing Realities
True-to-life precision room-scale tracking via SteamVR 1.0 base stations and controllers. Ultra-vibrant screen colours. Incredibly high contrast and uber-realistic sounds. VIVE Pro is engineered for professional-grade VR.
Spot Every Detail - High Resolution AMOLED Screens
See the difference with VIVE Pro. High resolution AMOLED screens, with super-rich colours and contrast, dazzle the eye and bring your imagination to life.
Designed for Comfort - Optimized Ergonomics
Optimized from top down for ergonomic comfort. Headset weight is evenly distributed to achieve a balanced centre of gravity. Suits a wide range of head shapes and sizes and is adjustable for different pupillary distances. VIVE Pro is ideal for extended sessions in VR.
Up to 3.5m X 3.5m Room-Scale Stage
Teleport around boundless virtual worlds sitting at your desk, or create a dedicated room-scale play area where you can physically walk around. SteamVR™ Tracking provides the best experience possible, so play the way that works for you – seated, standing or room-scale.
High-res Soundstage - 3D Spatial Audio
Hear every world as intended by its creator. The Hi-Res certified HMD and headphones are now integrated with 3D spatial sound to deliver for true-to-life immersive audio. The powerful amplifier is capable of driving high-impedance headphones - creating soundscapes that will change your world. The dual microphones allow for active noise cancellation as well as enabling Alert Mode and Conversation Mode - so you hear your surroundings while being immersed in any realities without the need of taking off the headset.
Fully Immersive
Precise, 360-degree controller and headset tracking, realistic graphics, directional audio and HD haptic feedback mean realistic movement and actions in the virtual world. It doesn’t get more first-person than this.
What's inside counts
Experience room-scale gameplay with precise motion tracking and natural controller gestures. Get a glimpse of the real world when you need it thanks to the front-facing camera. Open apps and games without taking off your headset. -
Form-fitting comfort
Adjustable headset strap provides balanced comfort for extended use. -
Real-world awareness
Front-facing camera blends real-world elements into the virtual world. -
Feast your eyes
High resolution and fast refresh rate deliver eye-popping graphics and smooth action. -
Adjustable ease
Interchangeable foam inserts and nose pads provide customized comfort - fits glasses too. -
Navigate naturally
Multi-function trackpad provides effortless precision and HD haptic feedback.
- HTC VIVE Pro Starter Kit - 3D virtual reality headset
- Virtual reality headset
- 3D Capable
- 2 microphones
- Sensors
- Proximity sensor, gyro sensor, G-sensor, IPD sensor
- Native Resolution
- 2880 x 1600 at 90 Hz
- Resolution per Eye
- 3.5" - 1440 x 1600
- Field of View
- 110°
- Input Connectors
- DisplayPort
- DisplayPort 1.2
- 2-year warranty
- Display Type
- Virtual reality headset / AMOLED
- 3D Capable
- Built-in Devices
- 2 microphones
- Native Resolution
VR Headset
- 1440 x 1600
- Diagonal Size per Eye
- 3.5"
- Field of View
- 110°
- Sensors
- Adjustable headband, interpupillary distance adjustment, SteamVR tracking technology, adjustable headphones, adjustable lens distance
Audio
- Headphone
- USB-C , DisplayPort
- Bluetooth interface
- Included Accessories
- Cleaning cloth, link box, face cushion (attached), 2 x earphone hole caps
- Cables Included
- 1 x SuperSpeed USB cable , 1 x DisplayPort cable
- DisplayPort 1.2
- OS Required
- Windows 10, Windows 8.1 or later
- Limited warranty - 2 years
