HTC Vive Pro Starter Kit
Quicklinx: F83YWS00 Mfr#: 99HAPY001-RET
£1,383.69 ex VAT
£1,660.42 inc VAT
Vive is an amazing virtual reality system. Let yourself be visually, physically and emotionally amazed by virtual worlds filled with inspiring characters, sights and sounds.
  • What's inside counts
    Experience room-scale gameplay with precise motion tracking and natural controller gestures. Get a glimpse of the real world when you need it thanks to the front-facing camera. Open apps and games without taking off your headset.
  • Form-fitting comfort
    Adjustable headset strap provides balanced comfort for extended use.
  • Real-world awareness
    Front-facing camera blends real-world elements into the virtual world.
  • Feast your eyes
    High resolution and fast refresh rate deliver eye-popping graphics and smooth action.
  • Adjustable ease
    Interchangeable foam inserts and nose pads provide customized comfort - fits glasses too.
  • Navigate naturally
    Multi-function trackpad provides effortless precision and HD haptic feedback.
HTC VIVE Pro Starter Kit - 3D virtual reality headset
Virtual reality headset
3D Capable
2 microphones
Sensors
Proximity sensor, gyro sensor, G-sensor, IPD sensor
Native Resolution
2880 x 1600 at 90 Hz
Resolution per Eye
3.5" - 1440 x 1600
Field of View
110°
Input Connectors
DisplayPort
DisplayPort 1.2
Display Type
Virtual reality headset / AMOLED
3D Capable
Built-in Devices
2 microphones
Native Resolution
VR Headset
Resolution per Eye
1440 x 1600
Diagonal Size per Eye
3.5"
Field of View
110°
Sensors
Adjustable headband, interpupillary distance adjustment, SteamVR tracking technology, adjustable headphones, adjustable lens distance
Audio
Headphone
USB-C , DisplayPort
Bluetooth interface
Cleaning cloth, link box, face cushion (attached), 2 x earphone hole caps
1 x SuperSpeed USB cable , 1 x DisplayPort cable
DisplayPort 1.2
Windows 10, Windows 8.1 or later
Brand: HTC
Price Range Ex VAT: 1000 - 1500
