HPE X372 54VDC 680W PS
Quicklinx: DYL5WS00 Mfr#: JL086A
For Aruba 3810M,3810M 16SFP+ 2-slot Switch,3810M 24G PoE+ 1-slot Switch,3810M 48G PoE+ 1-slot Switch
HPE Aruba X372 - power supply - hot-plug / redundant - 680 Watt
Power supply - hot-plug / redundant
830 g
Input Voltage
AC 100-240 V
Output Voltage
54 V
Power Capacity
680 Watt
8.31 cm x 4.01 cm x 22.56 cm
HPE Aruba 2930M 24, 2930M 24G, 2930M 40G, 2930M 48G, 3810M 24G, 3810M 40G, 3810M 48G, 6200F 12G
Input Voltage
AC 100-240 V
Output Voltage
54 V
Power Capacity
680 Watt
8.31 cm
4.01 cm
22.56 cm
830 g
HPE Aruba 2930M 24 Smart Rate POE+ 1-Slot, 2930M 24G POE+ 1-Slot, 2930M 40G 8 HPE Smart Rate PoE Class 6 1-slot Switch, 2930M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 2930M 48G POE+ 1-Slot, 3810M 24G PoE+ 1-slot Switch, 3810M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 3810M 48G PoE+ 1-slot Switch, 3810M 48G PoE+ 4SFP+ 1050W, 3810M 48G PoE+ 4SFP+ 680W, 6200F 12G Class4 PoE 2G/2SFP+ 139W Switch, 6200F 12G Class4 PoE 2G/2SFP+ 139W TAA Switch
