Do you need to accelerate the performance of your data-intensive application workloads? HPE Server Read Intensive (RI) Solid State Drives (SSDs) deliver high performance and endurance while reducing power consumption for customers with applications requiring high random read and write IOPs performance. HPE RI SSDs offer the highest performance for read intensive applications and typically have an endurance of <1 drive writes per day. All HPE SSDs are backed by over 2.4 million hours of the industry's most rigorous testing and qualification program ensuring reliable, high performing drives. HPE integrated firmware protects data from malicious attacks that could change or destroy it. The self-describing icons on the HPE SMART Carrier takes the guess work out of a drive's status and a "do not remove" button prevents data loss from human error. You can monitor the lifespan of your SSD with HPE SmartSSD Wear Gauge compatibility in management tools.
- HPE Value Endurance Enterprise Value M1 - SSD - 120 GB - SATA 6Gb/s
- Solid state drive - hot-swap
- Capacity
- 120 GB
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support
- 15 mm
- 3-year warranty
- Bundled with
- HP SmartDrive carrier
- Designed For
- ProLiant BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL388p Gen8 Base (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5")
- Capacity
- 120 GB
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- Bytes per Sector
- 512
- TRIM support
- 15 mm
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 430 MBps (read) / 205 MBps (write)
- 4KB Random Read
- 58000 IOPS
- 4KB Random Write
- 24000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 9 Watt
- Limited warranty - 3 years
- 0 °C
- 60 °C
- Designed For
- HPE ProLiant BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL388p Gen8 Base (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5")
