HP 1x4 KVM Console 6ft USB Cable 1.8m in length
Designed For:
HPE 600mm; ProLiant BL20p G3, DL140 G3, DL165 G5, DL180 G5, DL185 G5, DL320 G5p, DL360 G5, DL365 G5, DL370 G6, DL380 G5, DL385 G2, DL385 G5, DL385 G5p, DL585 G6, DL785 G5, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G3, ML150 G5, ML150 G6, ML330 G6, ML350 G6; Rack; Server Console Switch 1x4
- HPE USB Server Console Cable - video / USB cable - 1.8 m
- Video / USB cable
- Packaged Quantity
- 2 (specifications are for single item)
- Length
- 1.8 m
- Connectors
- 15 pin HD D-Sub (HD-15) , 4 pin USB Type A
- Designed For
- HPE 600mm; ProLiant BL20p G3, DL140 G3, DL165 G5, DL180 G5, DL185 G5, DL320 G5p, DL360 G5, DL365 G5, DL370 G6, DL380 G5, DL385 G2, DL385 G5, DL385 G5p, DL585 G6, DL785 G5, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G3, ML150 G5, ML150 G6, ML330 G6, ML350 G6; Rack; Server Console Switch 1x4
- Packaged Quantity
- Video / USB cable
- Length
- 1.8 m
- Connectors
- Designed For
- HPE 600mm x 1075mm Enterprise Pallet Rack, 600mm x 1075mm Enterprise Shock Rack , HPE ProLiant BL20p G3, DL140 G3, DL165 G5 Special Server, DL180 G5 Special Server, DL185 G5 Special Server, DL320 G5p, DL360 G5, DL360 G5 Performance, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6 Base, DL370 G6 High Performance, DL380 G5, DL380 G5 Base, DL380 G5 High Performance, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL585 G6, DL585 G6 Base, DL785 G5, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G3, ML150 G5, ML150 G6, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server , HPE Rack , HPE Server Console Switch 1x4
