Product
HPE USB-C To VGA Adapter
Quicklinx: C7HQWS00 Mfr#: N9K76AA
£26.25 ex VAT
£31.50 inc VAT
Drive your notebook or tablet's video content to an external display, TV, or projector with the HP USB-C to VGA Adapter.
  • One-cable connectivity
    Plug the adapter into your tablet or notebook's USB-C port and send your work to a monitor, projector or TV through the VGA port.
  • Take it to go
    Store the small adapter with you in your device's carrying case for quick projection wherever you work.
  • World-class support
    Rest easy with a one-year limited warranty.
HP - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
2560 x 1600
VGA
2.55 cm 1.3 cm
Length
15 cm
Enclosure Colour
1 year warranty
Chromebox G2; Elite Slice for Meeting Rooms G2; Elite x2; EliteBook 1040 G4, 1050 G1, 735 G5, 745 G5, 755 G5, 830 G5, 840 G5, 850 G5; EliteBook x360; EliteDesk 800 G4; ProBook 430 G6, 440 G6, 450 G5, 450 G6, 470 G5; ProBook x360; Spectre x360; ZBook 15v G5, 17 G5, Studio G5, Studio x360 G5; ZBook x2
Bus Type
USB-C
Max Resolution
2560 x 1600
VGA
High Bit Rate 2
Microsoft Windows 7 (32/64 bits) SP1, Windows 8, Windows 10
RoHS, WEEE, REACH
2.55 cm
1.3 cm
Length
15 cm
23.9 g
Enclosure Colour
Limited warranty - 1 year
HP Chromebook 13 G1 , HP Chromebox G2 , HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite , HP Elite x2 1012 G2, 1013 G3 , HP Elite x3 , HP EliteBook 1040 G3, 1040 G4, 1050 G1, 735 G5, 745 G5, 755 G5, 830 G5, 840 G5, 850 G5 , HP EliteBook x360 1012 G2, 1020 G2, 1030 G3, 1040 G5 , HP EliteDesk 800 G4 , HP Pro x2 612 G2 , HP ProBook 430 G5, 430 G6, 440 G6, 450 G5, 450 G6, 470 G5 , HP ProBook x360 11 G2, 11 G3, 440 G1 , HP ProDesk 600 G3 , HP Spectre x360 15-ch006tx , HP ZBook 15 G4 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Brand: HPE
Price Range Ex VAT: 0 - 50
