HPE TPM MODULE KIT
HPE TPM MODULE KIT
Quicklinx: 71DMWS00 Mfr#: 488069-B21
The TPM is a security component which enhances security capabilities for the server if it is running the HP-UX operating system. The TPM is a security chip that is unique to the server. It performs key security processes independent of other hardware components. The TPM creates and stores additional encryption keys from the root key of the system. The encryption keys created by the TPM encapsulate system application encryption keys to provide an additional layer of security for sensitive system data.
HPE Trusted Platform Module (TPM) hardware security chip
Hardware security chip
Apollo 4510 Gen9; ProLiant BL460c Gen8, BL660c Gen8, DL160 Gen8, DL180 Gen9, DL320e Gen8, DL360 G7, DL380 G6, DL560 Gen8, MicroServer Gen8, ML10 Gen9, ML10 v2, ML310e Gen8, ML350e Gen8, WS460c Gen8; SimpliVity 380 Gen9; StoreEasy 1450, 1850, 3850; Synergy 480 Gen10, 480 Gen9, 660 Gen9, 680 Gen9
HPE Apollo 4510 Gen9 , HPE ProLiant BL460c G7, BL460c Gen8, BL490c G7, BL620C G7, BL660c Gen8, BL680c G7, BL685c G7, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL180 Gen9, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Special Server, DL370 G6 High Performance, DL380 G6, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 G7 Base, DL580 G7 High Performance, DL585 G7 Performance, DL980 G7, MicroServer, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, WS460c Gen8 , HPE SimpliVity 380 Gen9 Node , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3800 G2, X3800sb G2 , HPE StorageWorks Network Storage System X1500 G2, X1600 G2, X1800 G2 , HPE StoreEasy 1450, 1850, 3850 Gateway Single Node , HPE Synergy 480 Gen10 Base Compute Module, 480 Gen10 Entry Compute Module, 480 Gen10 Performance Compute Module, 480 Gen10 Premium Backplane Compute Module, 480 Gen10 Standard BackPlane Compute Module, 480 Gen10 w/o Drives Compute Module, 480 Gen9 Compute Module, 660 Gen9 Base Compute Module, 660 Gen9 Compute Module, 660 Gen9 Entry Compute Module, 660 Gen9 Expanded Storage Compute Module, 660 Gen9 Performance Compute Module, 680 Gen9 4S-EX Base Compute Module, 680 Gen9 4S-EX Performance Compute Module
