Product
Brand
HPE T750 G2 HIGH VOLTAGE INTL
Quicklinx: 6B72WS00 Mfr#: AF447A
Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
HPE UPS T750 G2 - UPS - 750 VA
UPS - external
12.7 kg
Input Voltage
AC 220/230/240 V
Output Voltage
+ 6% / - 10%
Power Capacity
750 VA
Input Connectors
1 x power IEC 60320 C13
Output connectors
4 x power IEC 60320 C14
Lead Acid
Run Time (Up To)
5 min at full load
15 cm x 33.3 cm x 19.3 cm
3 years warranty
ProLiant DL120 Gen9, DL380 Gen9, DL60 Gen9, DL80 Gen9, MicroServer, MicroServer G7, MicroServer Gen8, ML10, ML110 G5, ML110 G6, ML110 G7, ML110 Gen9, ML115 G5, ML150 G6, ML150 Gen9, ML310 G5, ML310 G5p, ML330 G6
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
+ 6% / - 10%
Power Capacity
750 VA
Output Waveform
Sinewave
Lead Acid
Run Time (Up To)
5 min at full load
Recharge Time
24 hours
1 x management (USB) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
USB cable - external - 1.8 m , Serial cable - external - 1.8 m
Equipment Protection Value
250000 US Dollars
LED display, audible alarm
UL, VCCI, C-Tick, GOST, GS, NOM, EK, FCC, RoHS, ICES, S Mark
Software Included
Drivers & Utilities
Limited warranty - 3 years
5 - 95%
Sound Emission
45 dBA
15 cm
33.3 cm
19.3 cm
12.7 kg
HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, MicroServer, MicroServer G7, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML10, ML10 Entry, ML110 G5, ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML115 G5, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML310 G5, ML310 G5p, ML330 G6
