HPE Super DLTtape II 600GB Custom Labelled Data Cartridge (20
Quicklinx: 86H2WS00 Mfr#: Q2020AL
HP DLT/SDLT Data Cartridges offer high capacity and low cost per GB for customers with existing investments in DLT backup technology. HP SDLT II cartridges support DLTSage for improved media and drive diagnostics, enabling IT managers and network staff to better manage, predict and proactively prevent backup problems. DLTIce allows cartridges to be formatted as WORM tapes for compliance with regulations on data retention and archiving. To increase capacity, SDLT II transfers optical servo guide information to the other surface of the media, increasing the number of recording tracks on the data-bearing media surface. HP's DLT/SDLT media is exhaustively qualified for use with HP and non-HP DLT/SDLT drives. A continuous testing program in HP's media laboratory guarantees the high levels of quality uniquely specified by HP.
  • High capacity and low cost per GB for existing DLT/SDLT users
    Capacities range from 40 GB to 600 GB compressed, with sustained transfer rates from 1.5 MB/sec to 72 MB/sec.A thinner magnetic recording layer and a 40% smaller particle size achieves the highest capacity and lowest cost per GB in mid-range storage. Laser guided magnetic technology increases the number of tracks available for recording.
  • Ultra-reliable
    DLTSage data management allows you to monitor media and drive diagnostics to pre-empt and prevent backup system errors caused by tapes and drives which are nearing the end of their working lives.HP's media laboratory test both media and drives to a unique level of specification, including load/unload, shoeshine, drop testing and environmental stress testing.HP warrants DLT/SDLT cartridges for up to 30 years archival life and 1 million passes, regardless of the drive you use. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving.
  • Secure
    Standardizing on HP DLT/SDLT delivers the capacity to meet shrinking backup windows and interchangeable RW or WORM media without extra space or IT resource overhead.Industry standard technology ensures compatibility across HP and non-HP drives, with scalable capacity and performance. Cartridges are available as Custom Labeled, Non-Custom Labeled and non-labeled versions to fit with your data centre management criteria.
HPE SuperDLT II Custom Labelled Data Cartridge - Super DLT II x 20 - 300 GB - storage media
Storage media - Super DLT
Tape Cartridge
Super DLTtape II
Media Included Qty
20
Native Capacity
300 GB
Compressed Capacity
600 GB
Tape Length
630 m
Super DLT
Tape Cartridge
Super DLTtape II
Media Included Qty
20
Media
Native Capacity
300 GB
Compressed Capacity
600 GB
Tape Length
630 m
Archival Life
30 years
10 °C
20 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
