Product
Brand
HPE Storageworks MSA60 Modular Smart Array
Quicklinx: 4V31WS00 Mfr#: AG768AM
The HP StorageWorks 60 Modular Smart Array provides an end-to-end flexible platform in a high capacity 2U disk drive storage enclosure supporting 3.5" SAS and Serial ATA (SATA) drives. Manage your small and midrange business growing storage needs by deploying this low cost, flexible tiered storage system with up to almost 3.6TB of SAS storage or 9TB of SATA storage. The modular, scalable design of the MSA60 provides an extremely flexible platform allowing a customer to buy what is needed today and purchase additional capacity as data storage needs grow, instead of making a large up-front investment. This enclosure is designed to support the mixing of SAS and SATA drives in the same enclosure. Configuration and setup is easy with HP Array Configuration Utility (ACU). The MSA60 supports direct attach storage to HP ProLiant and HP Integrity Servers.
HPE StorageWorks Modular Smart Array 60 Starter Kit - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
6 TB
SAS, SATA
0 (installed) / 12 (max)
Supported Drives
SATA-150 / SAS
Storage Controller
1 x SAS (SATA 1.5Gb/s / SAS) - RAID 0, 1, 5, 6, 10
Hard Drive
0 HDD SATA 1.5Gb/s / SAS - hot-swap
44.8 cm x 59 cm x 8.8 cm
15.4 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-150 / SAS
Storage
6 TB
HDD Array External Interface
SAS, SATA
Storage Controller
1 x SAS (SAS)
Interface Type
SATA 1.5Gb/s / SAS
Cache / Buffer Size (Max)
512 MB
Supported Devices
Hard drive
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
HDD - hot-swap
0
Interface Type
SATA 1.5Gb/s / SAS
Expansion Bays
12 (total) / 12 (free) x hot-swap - 3.5" x 1/3H
44.8 cm
59 cm
8.8 cm
15.4 kg
Limited warranty - parts - 3 years
10 °C
35 °C
10 - 90%
