The HP Rack-mount Kits provide a high density, rack-mountable tape drive and RDX removable disk drive solution for both direct-attach SCSI, USB, or SAS backup and archiving applications. The HP 1U Rack-mount Kit supports DAT and LTO Ultrium internal tape drives, and RDX internal removable disk backup systems. The 1U rack-mount kit is available in SCSI, SAS and USB interfaces. With two LTO-6 Ultrium 6250 drives, the 1U SAS enclosure can provide a maximum compressed capacity of 12.5TB with a data transfer rate up to 2.8TB/hr. The HP 3U Rack-mount Kit holds two (2) full-height internal tape drives, four half-height internal tape drives, or a combination of one full height and two half-height tape drives. It is available in both SCSI and SAS interfaces. With four LTO-6 Ultrium 6250 SAS drives this enclosure solution can provide a maximum compressed capacity of 25TB.
Space-efficient Way to Rack-mount Tape Drives and RDX Backup Systems
HPE StoreEver Rack-mount Kits are ideal for customers who have limited space in their rack as it allows for a smaller footprint leaving valuable space for other key components in the data center.The 1U rack enclosure can hold up to two half-height drives.The 1U HPE StoreEver Rack-mount Kit allows users to mix a variety of technologies, including LTO Ultrium, as well as RDX removable disk technology.The enclosures support standard internal LTO tape drives and HPE RDX Removable Disk Backup Systems, allowing for drive upgrades when you need additional capacity or want to migrate to new generation of LTO tape drives or RDX removable disk technology. -
SAS and USB Interfaces to Suit your Environment
SAS versions of the 1U HPE StoreEver Rack-mount Kits allows customers to rack-mount SAS-based tape drives providing an alternative to internal models in racked environments.The 1U USB HPE StoreEver Rack-mount Kit is an industry first for enclosures, this solution will allow customers to support RDX removable hard-disk drives. -
Quick and Easy Installation
In addition to no tools required for installation, the 1U HPE StoreEver Rack-mount Kits provides top access and removable drive tray for easier access to LTO tape drives and RDX removable hard-disk drives.
- HPE StorageWorks SCSI Rack-Mount Kit - storage enclosure
- Storage enclosure
- Enclosure Type
- Rack-mountable - 3U
- Carbon
- 42.7 cm x 58.4 cm x 13.2 cm
- 12.3 kg
- Designed For
- StorageWorks DAT 40 Internal Tape Drive, DAT 72 Internal Tape Drive, DLT VS160, SDLT 600; StorageWorks Ultrium 1760, 1840, 232, 448, 460, 920, 960
- Storage enclosure
- Enclosure Type
- Enclosure Colour
- Carbon
- 2 x SCSI LVD/SE - 68 pin HD D-Sub (HD-68)
- Cables Included
- 1 x SCSI cable , 1 x SCSI cable kit
- Power Device
- Internal power supply
- 42.7 cm
- 58.4 cm
- 13.2 cm
- 12.3 kg
- 5 °C
- 40 °C
- 20 - 80%
- Designed For
- HPE StorageWorks DAT 40 Internal Tape Drive, DAT 72 Internal Tape Drive, DLT VS160, SDLT 600 , HPE StorageWorks Ultrium 1760, 1840, 232, 448, 460, 920, 960
