Your basket is empty
HPE StorageWorks 3U RackMount Kit
Quicklinx: 4KJHWS00 Mfr#: 274338-B22
The HP Rack-mount Kits provide a high density, rack-mountable tape drive and RDX removable disk drive solution for both direct-attach SCSI, USB, or SAS backup and archiving applications. The HP 1U Rack-mount Kit supports DAT and LTO Ultrium internal tape drives, and RDX internal removable disk backup systems. The 1U rack-mount kit is available in SCSI, SAS and USB interfaces. With two LTO-6 Ultrium 6250 drives, the 1U SAS enclosure can provide a maximum compressed capacity of 12.5TB with a data transfer rate up to 2.8TB/hr. The HP 3U Rack-mount Kit holds two (2) full-height internal tape drives, four half-height internal tape drives, or a combination of one full height and two half-height tape drives. It is available in both SCSI and SAS interfaces. With four LTO-6 Ultrium 6250 SAS drives this enclosure solution can provide a maximum compressed capacity of 25TB.
HPE StorageWorks SCSI Rack-Mount Kit - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 3U
42.7 cm x 58.4 cm x 13.2 cm
12.3 kg
StorageWorks DAT 40 Internal Tape Drive, DAT 72 Internal Tape Drive, DLT VS160, SDLT 600; StorageWorks Ultrium 1760, 1840, 448, 460, 960
Storage enclosure
Enclosure Type
Rack-mountable - 3U
Enclosure Colour
Carbon
2 x SCSI LVD/SE - 68 pin HD D-Sub (HD-68)
1 x SCSI cable , 1 x SCSI cable kit
Internal power supply
42.7 cm
58.4 cm
13.2 cm
12.3 kg
5 °C
20 - 80%
HPE StorageWorks DAT 40 Internal Tape Drive, DAT 72 Internal Tape Drive, DLT VS160, SDLT 600 , HPE StorageWorks Ultrium 1760, 1840, 448, 460, 960
