HPE - SSD - Read Intensive - 960 GB - SATA 6Gb/s
Quicklinx: G4T0WS00 Mfr#: P09691-B21
£1,180.92 ex VAT
£1,417.10 inc VAT
Do you need more performance from your sever or platform? HPE SSDs deliver advanced performance and endurance while reducing power consumption for customers with applications requiring high random read and write IOPs performance.
  • High performance, exceptional reliability, and efficiency for faster business results
    HPE SATA Read Intensive Solid-State Drives are ideal for big data analytics, cloud computing, active archiving, database applications, and data warehousing.
  • HPE Multi-Vendor SSDs offer longer SKU lifecycles and immediate availability on SATA SSDs
    HPE enhanced its extensive SSD portfolio with a Multi-Vendor SSD SKU offering that allows for extended SKU lifecycles, immediately available supply and preferably priced SATA SSDs.
Solid state drive - hot-swap
960 GB
NAND Flash Memory Type
Multi-level cell (MLC)
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Drive Class
Read Intensive
Digitally Signed Firmware
7 mm
3-year warranty
Bundled with
HPE Low Profile Converter
Apollo 4200 Gen9; ProLiant DL180 Gen10, DL20 Gen10, DL325 Gen10, DL360 Gen10, DL380 Gen10, ML110 Gen10, ML30 Gen10, ML350 Gen10
960 GB
3.5" LFF
SATA 6Gb/s
7 mm
Bundled with
Performance
Drive Class
Read Intensive
Drive Transfer Rate
600 MBps (external)
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
Power Consumption
1.23 Watt (idle) , 2.33 Watt (random read) , 2.33 Watt (random write) , 1.93 Watt (sequential read) , 2.63 Watt (sequential write) , 2.22 Watt (random read/write) , 2.63 Watt (maximum)
WEEE
Limited warranty - 3 years
HPE Apollo 4200 Gen9 (3.5") , HPE ProLiant DL180 Gen10 (3.5"), DL180 Gen10 Entry (3.5"), DL20 Gen10 Plus (3.5"), DL20 Gen10 Plus Base (3.5"), DL20 Gen10 Plus Entry (3.5"), DL20 Gen10 Plus High Performance (3.5"), DL20 Gen10 Plus Performance (3.5"), DL325 Gen10 (3.5"), DL325 Gen10 Base (3.5"), DL325 Gen10 Entry (3.5"), DL325 Gen10 Performance (3.5"), DL325 Gen10 SMB Solution (3.5"), DL325 Gen10 Solution (3.5"), DL360 Gen10 Plus (3.5"), DL360 Gen10 Plus All-NVMe Server for Software Defined Storage (3.5"), DL380 Gen10 Plus (3.5"), DL380 Gen10 Plus Network Choice (3.5"), ML110 Gen10 (3.5"), ML110 Gen10 Entry (3.5"), ML110 Gen10 Performance (3.5"), ML110 Gen10 Solution (3.5"), ML30 Gen10 (3.5"), ML30 Gen10 Entry (3.5"), ML30 Gen10 Performance (3.5"), ML30 Gen10 Plus (3.5"), ML30 Gen10 Plus Entry (3.5"), ML30 Gen10 Plus Performance (3.5"), ML30 Gen10 Solution (3.5"), ML350 Gen10 (3.5"), ML350 Gen10 Base (3.5"), ML350 Gen10 Entry (3.5"), ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
