Your basket is empty
HPE RDX Removable Disk Backup System - RDX drive - SuperSpeed USB 3.0 - internal - with 1 TB Cartridge
Quicklinx: B0MQWS00 Mfr#: B7B67A
HPE RDX Removable Disk Backup System is a rugged, removable, easy-to-use, cost effective, disk backup solution for servers and workstations. It is the ideal backup solution for remote locations or small to medium businesses with little or no IT resources that are in less than ideal locations such as a busy office, field base sites, or business that require mobility. The new HPE RDX+ is perfect for these environments due to its ruggedness and the fact that it only requires a USB connection, no separate power source/cord required. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station. The HPE RDX Removable Disk Backup System offers fast disk-based performance with the ability to store 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360 GB/hr.
RDX drive - internal
SuperSpeed USB 3.0
14.68 cm x 17.07 cm x 4.14 cm
635 g
Storage Removable
RDX - 5.25" x 1/2H
Media Type
RDX - 5.25"
Data Transfer Rate
100 MBps (external) / 600 MBps (internal)
Bundled with
1 TB Cartridge
ProLiant DL360 G7, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance
SuperSpeed USB 3.0
14.68 cm
17.07 cm
4.14 cm
635 g
Bundled with
1 TB Cartridge
Storage Removable
RDX - 5.25" x 1/2H
Media Type
RDX - 5.25"
Data Transfer Rate
Average Seek / Access Time
12 ms
1 x SuperSpeed USB 3.0 - 9 pin USB Type B
Compatible Bay
1 x 5.25" x 1/2H - front accessible
Media Included Qty
1
1 x USB cable
MTBF
550,000 hours
VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, UL 60950, CISPR 22, FCC
6.6 Watt
Software Included
Drivers & Utilities, HP RDX Continuous Data Protection Software
5 °C
45 °C
20 - 80% (non-condensing)
HPE ProLiant DL360 G7, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance
