The HP PS110 Wireless 11n VPN Router Series is an ideal all-in-one solution for small businesses, purpose built to work with HP ProLiant Gen9 and Gen8 Servers. This business-class router includes a 4-port Gigabit Ethernet switch, an 802.11n Access Point for wireless connectivity, Gigabit Ethernet WAN interface for Internet connectivity and robust security features like SPI firewall and VPN technology to safeguard your organization. It features auto-discovery and monitoring of the HP ProLiant Server families and its innovative design allows it to be stacked on the HP ProLiant MicroServer Gen8.
Keep Small Business Users Connected and Productive
The HP PS110 Wireless 11n VPN Router Series includes high-speed networking with a built-in, 4-port Gigabit Ethernet switch to make certain your small business has fast access to the data and files needed to get the job done.Employees can stay productive while roaming throughout the office with integrated IEEE 802.11n single radio dual band wireless technology with 3X3 MIMO antennas that supports high-speeds at 5 GHz or 2.4 GHz.Advanced Quality of Service (QoS) helps prioritize time-sensitive traffic for reliable delivery.Delivers increased business productivity and reliable Internet connectivity with Gigabit Ethernet WAN interface for high-performance connectivity to the Internet, remote workers and locations. -
Easy to Use and Manage
The HP PS110 Wireless 11n VPN Router Series introduces the HP Networking Web interface design with intuitive configuration tasks, troubleshooting tools and proactive monitoring in a clean, user-friendly layout.An Easy Setup Wizard allows you to quickly setup your network and connect your organization.Simplifies administration of the router and HP ProLiant Gen9/Gen8 Servers by enabling a centralized view of the IT infrastructure. The router auto-discovers and monitors the servers and reports real-time health status via the HP Integrated Lights-Out (iLO) interface.Features like email alerts, logs , Alert LED proactively notify users of attacks and anomalies in the network for quick resolution with reduced downtime. -
Protects Your Organization from Unauthorized Access
The HP PS110 Wireless 11n VPN Router Series features a Stateful Packet Inspection Firewall, combined with features like WPA/WP2 encryption, 802.1x, URL filter, Content Filters and Trusted Users Management to keep your network safe from outside threats and unauthorized access.This series offers mobile workers and offices protected connectivity over the public internet through virtual private network (VPN) complete with enterprise-grade encryption and authentication.With comprehensive, time-based rules, the router series can be set to automatically connect and disconnect features such as the wireless radios, URL filters, and content filters to restrict access to specific times of day. -
Flexibility that Fits Your Business
The HP PS110 Wireless 11n VPN Router Series is future-ready with iPv6 support.The sleek, unobtrusive design with internal wireless antennas fits well in any setting. It is specifically designed for physical stacking on the HP ProLiant MicroServer Gen8.The Wireless Distribution System feature allows you to scale your wireless network as your organization grows by providing an extremely flexible and cost effective way to link or extend wireless connectivity.
- HPE PS110 (WW) - wireless router - Wi-Fi - desktop, wall-mountable
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop, wall-mountable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- VPN throughput: 30 Mbps , NAT throughput: 920 Mbps
- Capacity
- IPSec VPN tunnels: 5 , Concurrent sessions: 5 , VLANs supported: 4
- PPTP, L2TP, NTP, IPSec, ARP, DHCP
- Routing Protocol
- RIP-1, RIP-2, IGMP, static IPv4 routing, static IPv6 routing, RIPng
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTPS
- Firewall protection, Layer 2 switching, DHCP support, NAT support, VPN support, IGMP snooping, traffic shaping, DoS attack prevention, content filtering, manageable, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, IP address filtering, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Multiple SSID support, IPv4 support, fanless, Network Access Control (NAC), DiffServ Code Point (DSCP) support, Wi-Fi Protected Setup (WPS v2), traffic remarking
- IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
- Power
- AC 120/230 V
- 23 cm x 23.7 cm x 4.25 cm
- 1 kg
- 3-year warranty
- Designed For
- ProLiant MicroServer Gen8 Performance
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Capacity
- MAC Address Table Size
- 2048 entries
- Routing Protocol
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, UL 60950-1, EN 60950-1, CAN/CSA-C22.2 No. 60950-1
- Processor
- 1 x MIPS 700 MHz
- Flash Memory
- 128 MB
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Voltage Required
- AC 120/230 V
- 9.5 Watt
- MTBF
- 51.54 years
- Software Included
- HP Intelligent Management Center
- 23 cm
- 23.7 cm
- 4.25 cm
- 1 kg
- Limited warranty - advance hardware replacement - 3 years - response time: next business day , Technical support - phone consulting - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Designed For
- HPE ProLiant MicroServer Gen8 Performance
