HPE ProLiant ML350p Intel Xeon E5-2620v2 8GB No HDD
Quicklinx: 9PVBWS00 Mfr#: 736958-421
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
How are you planning to deploy and manage multiple servers at your company's growing number of branch offices? The HP ProLiant ML350p Gen8 Server series is the latest generation of the best-selling ProLiant ML 2P servers delivering best-in-class performance, availability, maximum expandability and simplified management for remote branch offices of large enterprises, growing businesses and data centers.
  • Improved Capacity and Performance on Compute and Storage
    Intel Xeon processor E5-2600 v2 product family offers increased performance, improved security and efficiency for demanding workloads.The HPE Smart Storage Administrator management and configuration application provides a single pane of glass for HPE Smart Storage products and solutions.HPE Smart Array Controllers maximize data availability, performance and capacity.HPE SmartMemory, with speeds up to 1866 MHz, prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency.
  • Availability, Expandability and Serviceability - A Winning Combination
    User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Storage, HPE Smart Socket guides, and tool-less access to components.Provides plenty of room to grow to meet future needs with options for a second processor, PCIe slots, HPE Smart Memory with capacity up to 768GB, and internal storage configurations with up to 24 SFF or 18 LFF hard drives.HPE SmartDrive technology improves serviceability and prevents data loss with features such as icon-based status display and Do Not Remove LED.
  • Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
    HPE iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HPE iLO, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while decreasing Time-To-Resolution.HPE Insight Online with HPE remote support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE Smart Update, including HPE SUM, SPP and other products, reduces deployment time and update complexity by systematically and securely updating server infrastructure in the data center; in most cases the downtime is limited to a single reboot.
  • Energy Efficiency by Design
    First in industry to include 3D array of temperature sensors to help precisely control server fans to direct cooling and reduce unnecessary fan power, saving on cooling costs.High efficiency 80 PLUS certified HPE Common Slot Power Supplies provide up to 94% efficiency (Platinum) and support HP's Power Discovery Services.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
HPE ProLiant ML350p Gen8 Base - tower - Xeon E5-2620V2 2.1 GHz - 8 GB - no HDD
Server - tower - administrator password, system password, power-on password, serial port I/O control
Height (Rack Units)
5U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon E5-2620V2 / 2.1 GHz (, up to 2.6 GHz, (6-core)
Processor Main Features
Hyper-Threading Technology, Intel QuickPath Interconnect, Intel Turbo Boost Technology 2
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
8 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 3.0 x8 (Smart Array P420i with 512MB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200
1GbE
Power Redundancy
Optional
21.8 cm x 74 cm x 46.2 cm
31.9 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 5U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
2.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 384 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
24 (Total) / 23 (empty)
Registered, Online Spare Memory, quad channel memory architecture, low-voltage, HP SmartMemory
Configuration Features
1 x 8 GB
RAM Supported
PC3-14900 - 384 GB registered , PC3-12800 - 384 GB - low voltage - registered , PC3-14900 - 768 GB Load-Reduced , PC3-14900 - 128 GB unbuffered - Advanced ECC , PC3-12800 - 128 GB - low voltage - unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
512 MB
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Input Device
Mouse
Mouse
USB
Integrated
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
24 (total) / 23 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 4 (total) / 4 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x SD card (internal)
1 x serial , 1 x VGA , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 10 x USB 2.0 (4 front, 4 rear, 2 internal)
Administrator password, system password, power-on password, serial port I/O control
ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Gold
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Ubuntu, Oracle Solaris, Citrix XenServer
21.8 cm
74 cm
46.2 cm
31.9 kg
10 °C
35 °C
10 - 90% (non-condensing)
9PVB C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
