Are you searching for a server to meet the requirements of your small- to medium-sized growing business? The HP ProLiant ML350e Gen8 v2 Server delivers exceptional value in a less than 24-inch chassis depth for a business with a limited budget. Designed as a dual-socket tower server, it provides essential performance and features with great configuration flexibility and expandability. With built-in innovations that simplify server deployment and management, your business can continue to reap the benefits on a daily basis, while expansion options allow you to grow as needed. Requiring only a low initial capital outlay, the HP ProLiant ML350e Gen8 v2 Server provides an excellent return on investment.
Right Essentials for the Budget Conscious
The HP ProLiant ML350e Gen8 v2 Server provides essential performance and features delivering exceptional value, ideal for a business with a tight budget.Supports up to two Intel Xeon E5-2400 v2 processors offering improved performance, efficiency and security.Designed to protect your investment, the HP ProLiant ML350e Gen8 v2 Server is reliable and secure, with redundant storage and power supply options to increase system uptime.Latest HP Smart Array Controllers are designed to maximize data availability, performance and capacity. -
Designed to Grow with Your Business
The HP ProLiant ML350e Gen8 v2 Server has a chassis depth of less than 24 inches, saving precious real estate space.It allows your business to scale and grow with support for up to two processors, 12 DIMM slots, 16 small form factor (SFF) or 8 large form factor (LFF) drives, 6 PCIe slots, and 8 USB ports.The new NVIDIA Quadro K2000 GPU supports any dedicated graphics applications, giving you more value for your investment.It requires low upfront investment, while providing expansion capability to meet growing business needs.The built-in technologies not only automate mundane IT tasks, but also improve productivity and efficiency so the business can focus on growing. -
Built-in Innovations that Simplify Management and Free Up Limited IT Resources
With embedded management tools, the HP ProLiant ML350e Gen8 v2 Server simplifies server management and maintenance tasks, enabling quick and simple deployment (HP Intelligent Provisioning), system health monitoring (HP Active Health System), and ease of firmware updates (HP Smart Update Manager).HP Smart Storage Administrator provides a single display screen for management and configuration of all HP Smart Storage products and solutions.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HP SmartDrives, HP Smart Socket guides, and tool-less access to components. -
Proactive Service and Support to Redefine Service Experience
The HP ProLiant ML350e Gen8 v2 Server offers HP proactive support services, which integrate industry leading performance, uptime, and productivity into a personalized, simplified support experience.HP Insight Online with HP Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.Through HP ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.
- HPE ProLiant ML350e Gen8 Entry - tower - Xeon E5-2403 1.8 GHz - 2 GB - no HDD
- Server - tower - administrator password, system password, power-on password, serial port I/O control
- Height (Rack Units)
- 5U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2403 / 1.8 GHz (Quad-Core)
- Cache Memory
- 10 MB L3 Cache
- Cache Per Processor
- 10 MB
- RAM
- 2 GB DDR3 SDRAM - PC3-10600
- Storage Controller
- SATA (SATA 6Gb/s) - PCIe 2.0 x4 (HP Dynamic Smart Array B120i)
- Server Storage Bays
- 3.5"
- Hard Drive
- No HDD
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 21.8 cm x 74 cm x 46.2 cm
- 25.95 kg
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower - 5U
- 2-way
- Internal Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5-2403
- Clock Speed
- 1.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- L3 Cache - 10 MB
- 10 MB
RAM
- Installed Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 12 (Total) / 11 (empty)
- Unbuffered, HP SmartMemory
- Configuration Features
- 1 x 2 GB
- RAM Supported
- PC3-12800 - 192 GB registered , PC3-12800 - 96 GB unbuffered - Advanced ECC , PC3-10600 - 96 GB - low voltage - unbuffered - Advanced ECC , PC3-10600 - 192 GB - low voltage - registered
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B120i
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
Input Device
- Mouse
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC361i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1s, IEEE 802.3az
- Bays
- 3 external 5.25" x 1/2H , 4 (total) / 4 (free) x internal 3.5" LFF
- Slots
- 2 (total) / 1 (free) x CPU , 12 (total) / 11 (free) x DIMM 240-pin , 1 (total) / 1 (free) x SD card , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode)
- 1 x serial , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 10 x USB 2.0 (4 front, 4 rear, 2 internal)
- Administrator password, system password, power-on password, serial port I/O control
- ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply
- Voltage Required
- Power Provided
- 460 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 21.8 cm
- 74 cm
- 46.2 cm
- 25.95 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
