HPE ProLiant ML350 Intel Xeon Silver 4110 16GB 300GB
Quicklinx: DDSFWS00 Mfr#: 878761-035
Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers. The HPE ML350 Gen10 server leverages the scalable processor with high performance gain and increase in cores, plus the DDR4 SmartMemory. The shorter re-designed rackable chassis provides flexibility, that can expand as your business needs grow. The HPE ML350 Gen10 server helps you transform to a digital business with more agility and all within your limited IT budget.
  • Perform with unmatched versatility
    The HPE ProLiant ML350 Gen10 server supports up to two scalable processors, offering unparalleled performance. Up to 24 DIMM slots to support the 2600 MT/s HPE DDR4 SmartMemory, reducing data loss and downtime with the Fast Fault Tolerance feature, while increasing workload performance and power efficiency. Graphic processing unit (GPU) expansion supports up to four units to accelerate performance in virtual desktop Infrastructure (VDI) applications and machine learning for financial services, surveillance and security, educational and scientific research, retail and medical imaging.
  • Expand, when your business needs grow
    The HPE ProLiant ML350 Gen10 server delivers expandability. Large expansion capacity with (8) PCIe slots, (6) USB ports, 5U rack conversion, and power supply options. Embedded 4x1GbE provides you flexibility of networking bandwidth and fabric, so you can scale and adapt to different needs as your business grows.
HPE ProLiant ML350 Gen10 - tower - Xeon Silver 4110 2.1 GHz - 16 GB - HDD 2 x 300 GB
Server - tower
Height (Rack Units)
4U
Region: United Kingdom
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (, up to 3 GHz, (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
2 x HDD 300 GB - SAS 12Gb/s
Optical Storage
No optical drive
Video Memory
16 MB
1GbE
Power Redundancy
17.4 cm x 64.8 cm x 46.25 cm
21 kg
Manufacturer Selling Program
HPE Top Value
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Tower - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory, 6-channel memory architecture
Configuration Features
1 x 16 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC
Hard Drive
HDD
2 x 300 GB
Interface Type
SAS 12Gb/s
Enterprise, Digitally Signed Firmware
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA, DisplayPort
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 369i
Remote Management Protocol
SNMP 3, SMASH CLP
Remote Management Controller
Integrated Lights-Out Advanced Management (ASIC)
Wake on LAN (WoL), PXE support
Bays
8 (total) / 6 (free) x hot-swap 2.5" SFF
Slots
3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x serial , 1 x VGA , 1 x DisplayPort , 4 x LAN (Gigabit Ethernet) , 2 x HPE iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x USB 2.0 (1 internal)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
AES, FIPS 140-2, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
HPE Top Value
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, VMware ESXi 6.5, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, SuSE Linux Enterprise Server 12 SP2, ClearOS, VMware ESXi 6.0 update 3
Sustainability Information
ENERGY STAR Certified
17.4 cm
64.8 cm
46.25 cm
21 kg
10 °C
35 °C
8 - 90% (non-condensing)
