Need to increase your business productivity and improve operations while balancing your employees' mobility, security and collaboration needs, all within your limited IT budget? HPE ProLiant ML350 Gen9 Server delivers a class-leading combination of performance, expandability, manageability, reliability and serviceability making it the choice for enterprise data centers, expanding SMBs and remote offices of larger businesses. ML350 Gen9 Server leverages the Intel Xeon E5-2600 v3 and v4 processors with up to 21% performance gain, plus the latest HPE DDR4 SmartMemory offering up to 23% performance increase. Additional support for 12 Gb/s SAS, embedded 4x1GbE NIC with a broad range of graphics and compute options. Manage your HPE ProLiant Server in any IT environments by automating the most essential server lifecycle management tasks: deploy, update, monitor, and maintain with ease. The ML350 Gen9 Server is ideal for enterprise IT infrastructure to mission critical applications.
Performance with Unmatched Capacity and Reliability
The HPE ProLiant ML350 Gen9 Server supports up to (2) Intel Xeon E5-2600 v3 or v4 processors offering improved performance.HPE Smart Array Controllers are designed to increase 12 Gb/s performance, data availability and storage capacity while providing the flexibility in choice of solutions that are simple to manage.Up to (24) DIMM slots to support HPE DDR4 SmartMemory 2400MHz, helping to prevent data loss and downtime with enhanced error handling while improving workload performance and power efficiency. -
Availability, Expandability and Serviceability - A Winning Combination
The HPE ProLiant ML350 Gen9 Server offers expandability with greater capacity with (8) to (24) LFF, (8) to (48) SFF drive options and increased I/O expansion.Large expansion capacity with (9) PCIe expansion slots, (8) USB ports, 5U Rack conversion, and Power Supply options.Embedded 4x1Gbe and choice of HPE PCIe standup 1GbE, 10GbE or 25GbE Adapters provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Wider GPU support (4) to boost performance in graphic and VDI applications for financial services, education, scientific research, and medical imaging.Worldwide availability, service and support with a complete range of Foundation Care offerings from installation to extended support. -
Agile Infrastructure Management for Essential Administration
The HPE ProLiant ML350 Gen9 Server provides powerful converged management capabilities for the infrastructure lifecycle with embedded server management for provisioning, updating and diagnostic support with HPE iLO.Configure in Unified Extensible Firmware Interface (UEFI) boot mode to provision local and remote servers with HPE iLO with Intelligent Provisioning and Scripting Toolkits.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Optimize firmware and driver updates and reduce downtime with Smart Update Solution, consisting of Smart Update Manager (SUM) and Service Pack for ProLiant (SPP). -
Energy Efficiency by Design
The HPE ProLiant ML350 Gen9 Server offers ENERGY STAR qualified server configurations illustrate the HPE continued commitment to helping customers conserve energy and save money.Next generation high efficiency redundant HPE Flexible Slot Power Supplies provide up to 96% efficiency (Titanium).Improved ambient temperature standard with ASHRAE A3 and A4 helps you reduce cooling costs.
- HPE ProLiant ML350 Gen9 Base - tower - Xeon E5-2620V3 2.4 GHz - 16 GB - no HDD
- Server - tower - administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
- Height (Rack Units)
- 5U
- Localisation
- Region: United Kingdom
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V3 / 2.4 GHz (, up to 3.2 GHz, (6-core)
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 16 GB (installed) / 384 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (Smart Array P440ar with 2GB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 21.9 cm x 76.9 cm x 46.4 cm
- 30 kg
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower - 5U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2620V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 16 GB / 384 GB (max)
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
- Configuration Features
- 1 x 16 GB
- RAM Supported
- PC4-17000 - 768 GB Load-Reduced , PC4-17000 - 384 GB registered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Smart Array P440ar with 2GB FBWC
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 331i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 24 (total) / 23 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 4 (total) / 4 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 2 x USB 3.0 , 4 x USB 2.0 (2 front, 2 rear)
- Administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Citrix XenServer, Canonical Ubuntu
- 21.9 cm
- 76.9 cm
- 46.4 cm
- 30 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
