HPE ProLiant ML350 Gen10 Xeon Silver 4110 16GB
Quicklinx: DR9HWS00 Mfr#: P04674-425
Case Style: Tower
Processor Type: Xeon Silver
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 16GB
45 in stock
£1,436.74 ex VAT
£1,724.08 inc VAT
Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers. The shorter re-designed rackable chassis provides flexibility that can expand as your business needs grow. HPE ProLiant ML350 Gen10 server helps you transform to a digital business with more agility and all within your limited IT budget.
  • Perform with Unmatched Versatility
    HPE ProLiant ML350 Gen10 supports up to two Intel Xeon Scalable processors, starting from Bronze through Platinum, 4 cores expanding up to 28 core processors offering unparalleled performance.Up to 24 DIMM slots to support the 2600 MT/s HPE DDR4 SmartMemory, reducing data loss and downtime with the HPE Gen10 technology licensed Fast Fault Tolerance feature while increasing workload performance and power efficiency.It supports a wide range of solutions from Azure to Docker to ClearOS along with the traditional operating systems.GPU expansion supports up to four units to accelerate performance in VDI applications and machine learning for financial services, surveillance and security, educational and scientific research, as well as retail and medical imaging.
  • Expand When Your Business Needs Grow
    HPE ProLiant ML350 Gen10 delivers expandability with a wide range of drive upgrade options. Supporting 8 to 24 SFF or 16 SFF when mixed with optional 8 NVMe PCIe solid state drives, 4 to 12 LFF hot plug or non-hot plug drive options protecting your IT investment in hybrid environment.Large expansion capacity with (8) PCIe slots, (6) USB ports, 5U rack conversion, and power supply options.Embedded 4x1GbE and the choice of PCIe standup 1GbE, 10GbE or 25GbE adapters provide you the flexibility of networking bandwidth and fabric so you can scale and adapt to different needs as your business grows.
  • Security Innovations
    HPE ProLiant ML350 Gen10 is one of the HPE industry standard servers with major firmware anchored directly into the silicon security protection built in across the server lifecycle starting with Silicon Root of Trust.Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and reliably store artifacts used to authenticate the server.
  • Industry Leading Services and Ease of Deployment
    The HPE ProLiant ML350 Gen10 comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk, and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an effective solution. Professional Services enable rapid deployment of solutions and Operational Services provide ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant ML350 Gen10 Solution - tower - Xeon Silver 4110 2.1 GHz - 16 GB
Server - tower
Height (Rack Units)
4U
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 768 GB (max) - DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (HPE Smart Array E208i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
GigE
Power Redundancy
Optional
17.4 cm x 64.8 cm x 46.25 cm
21 kg
Manufacturer Selling Program
HPE Top Value
Limited warranty - parts and labour - 3 years - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 768 GB (max)
DDR4 SDRAM
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, HPE SmartMemory
Configuration Features
1 x 16 GB
RAM Supported
PC4-21300 - 3 TB Load-Reduced , PC4-21300 - 768 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 369i
Remote Management Protocol
SNMP 3, SMASH CLP
Remote Management Controller
Integrated Lights-Out Advanced Management (ASIC)
Wake on LAN (WoL), PXE support
Bays
8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 4 (total) / 4 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height
1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HP iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x USB 2.0 (1 internal) , 1 x HP iLO - Type A (1 in front)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
AES, FIPS 140-2, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
HPE Top Value
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, VMware ESXi 6.5, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, SuSE Linux Enterprise Server 12 SP2, ClearOS, VMware ESXi 6.0 update 3
17.4 cm
64.8 cm
46.25 cm
21 kg
10 °C
35 °C
8 - 90% (non-condensing)
Case Style: Tower
Brand: HPE
Price Range Ex VAT: 1000 - 1500
