HPE ProLiant ML350 Gen10 Tower Intel Xeon Gold 5218 32GB
Quicklinx: F8M6WS00 Mfr#: P11053-421
Case Style: Tower
Processor Type: Xeon Gold
Hard Disk Capacity: 0GB
Processor Speed: 2.3GHz
Installed Memory: 32GB
£6,596.20 ex VAT
£7,915.44 inc VAT
Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers.
  • Perform with incredible versatility
    The HPE ProLiant ML350 Gen10 server supports a wide range of solutions for financial services, surveillance and security, educational and scientific research, retail and medical imaging.
  • Expand when your business needs grow
    The HPE ProLiant ML350 Gen10 server delivers expandability with a wide range of drive upgrade options, protecting your IT investment in hybrid environment.
  • Security innovations
    Secure recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.
HPE ProLiant ML350 Gen10 High Performance - tower - Xeon Gold 5218 2.3 GHz - 32 GB - no HDD
Server - tower
Height (Rack Units)
4U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon Gold 5218 / 2.3 GHz (, up to 3.9 GHz, (16-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
22 MB L3 Cache
Cache Per Processor
22 MB
RAM
32 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
1GbE
Power Redundancy
Software Included
HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
17.4 cm x 64.8 cm x 46.25 cm
21 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 22 MB
Cache Per Processor
22 MB
RAM
Installed Size
32 GB / 1.5 TB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, Online Spare Memory, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
1 x 32 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 369i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out Advanced Management (ASIC)
Wake on LAN (WoL), PXE support
Bays
8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 4 (total) / 4 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height
1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x USB 2.0 (1 internal) , 1 x HPE iLO - Type A (1 in front)
6 fan modules
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
17.4 cm
64.8 cm
46.25 cm
21 kg
10 °C
35 °C
8 - 90% (non-condensing)
Warranty Packs (2)
F8M6 HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,204.34
F8M6 HPE Installation Service - installation / configuration In Stock £332.81
Internal Hard Drives (7)
F8M6 HPE 1TB 6G SATA 7.2K 2.5IN SFF In Stock £406.28
F8M6 HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD In Stock £500.78
F8M6 HPE 300GB SAS 10K SFF SC DS-STOCK In Stock £124.49
F8M6 HPE 300GB SAS 15K SFF SC DS-Stock In Stock £155.29
F8M6 HPE 600GB SAS 10K SFF SC DS HDD In Stock £169.57
F8M6 HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £191.25
F8M6 HPE 600GB SAS 15K SFF SC DS HDD In Stock £223.08
Other bundles (2)
F8M6 HPE HP Ethernet 1Gb 4-port 331T Adapter In Stock £81.28
F8M6 HPE Ethernet 1GB 4-Port 366T Adapter In Stock £164.89
Case Style: Tower
Brand: HPE
Price Range Ex VAT: £1500+
