Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers. The shorter re-designed rackable chassis with multiple upgrade options provides flexibility that can expand as your business needs grow. It supports 12 Gb/s SAS, NVMe SSD, embedded 4x1GbE NIC with a broad range of graphics and compute options. The HPE ML350 Gen10 Server helps you transform to a digital business with more agility and all within your limited IT budget.
Perform with incredible versatility
The HPE ProLiant ML350 Gen10 server supports a wide range of solutions for financial services, surveillance and security, educational and scientific research, retail and medical imaging. -
Expand when your business needs grow
The HPE ProLiant ML350 Gen10 server delivers expandability with a wide range of drive upgrade options, protecting your IT investment in hybrid environment. -
Security innovations
Secure recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.
- HPE ProLiant ML350 Gen10 - tower - Xeon Bronze 3204 1.9 GHz - 16 GB
- Server - tower
- Height (Rack Units)
- 4U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Bronze 3204 / 1.9 GHz (6-core)
- Cache Memory
- 8.25 MB L3 Cache
- Cache Per Processor
- 8.25 MB
- RAM
- 16 GB (installed) / 768 GB (max) - DDR4 SDRAM
- Storage Controller
- RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software RAID)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 17.4 cm x 64.8 cm x 46.25 cm
- 21 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Tower - 4U
- 2-way
- Hot-Swap Bays Qty
- 4
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon Bronze 3204 / 1.9 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C622
Cache Memory
- Installed Size
- L3 Cache - 8.25 MB
- 8.25 MB
RAM
- Installed Size
- 16 GB / 768 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2933 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 12 (Total) / 11 (empty)
- Registered, slots 13 - 24 are available in two-processor configuration only
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 1.5 TB Load-Reduced , 768 GB registered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software RAID
- Channel Qty
- 14
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA, DisplayPort
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HPE 369i
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out Standard
- Wake on LAN (WoL), ACPI support, PXE support
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" LFF
- Slots
- 1 (total) / 1 (free) x microSD Card (internal) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode)
- 1 x VGA , 1 x serial , 1 x DisplayPort , 4 x LAN (Gigabit Ethernet) , 1 x HP iLO , 1 x HP iLO (1 in front) (service port) , 4 x USB 3.0 (2 front, 2 rear)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
- Power supply
- Installed Qty
- 1
- Max Supported Qty
- 2
- Nominal Voltage
- Power Provided
- 500 Watt
Operating System / Software
- OS Certified
- CentOS, Microsoft Windows Server 2012 R2, SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, VMware ESXi 6.5, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, SuSE Linux Enterprise Server 12 SP2, ClearOS, VMware ESXi 6.0 update 3
- Software
- HPE OneView Standard (free download)
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 17.4 cm
- 64.8 cm
- 46.25 cm
- 21 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
